Author Topic: how to make a radio control working bow door on a landingcraft  (Read 5493 times)
murphy1570
« on: February 01, 2013, 12:25:53 am »
Hello folks can anyone who has made a bow door to work preferably watertight!!!) on a 1:35 scale model of the Italeri landing craft lcvp or similar? or similar model and what gear to use and who might supply the gear needed, or if ther is a post of similar prject on this or any foum?
Thanks all the best, John.
Umi_Ryuzuki
    • Models and Miniatures
Re: how to make a radio control working bow door on a landingcraft
« Reply #1 on: February 01, 2013, 12:46:46 am »
Build a long throw servo arm, and place the control arm down near the hinge at the base of the door/ramp.
That will give the bow door plenty of throw. For water tight, the bow of these boats, and
the raised deck behind the door are enough to keep the water out. However, what I did was
allow a little space around the opening for a gasket. Then I applied a bead of silicone caulking
around the base, and either side of the opening. I placed a piece of plastic food wrap across the
inside of the door/ramp, and then closed the door.  Let the caulking squeeze out, and once cure, then
trim it flush to the edges of the opening. The plastic food wrap will keep the door from being sealed up
against the opening, and it should be able to drop back down after the caulking cures.
« Reply #2 on: February 01, 2013, 09:45:03 am »
How big a servo did you use Umi?
Umi_Ryuzuki
« Reply #3 on: February 01, 2013, 06:45:53 pm »
Hi Martin,
I just used a standard servo.
The servo arm, however, I extended by at least an inch.
pettyofficernick
« Reply #4 on: February 02, 2013, 12:30:48 am »
The Speedline Models landing craft uses a sailwinch and a system of cables to open and close the bow door, which I assume, is what was used on full size......
murphy1570
« Reply #5 on: February 02, 2013, 12:58:20 am »
Helo folks
Thanks for the helpful replies to date any more contributions or advice are more than wecome.
Thanks again all the best, John.
goBulawayo
« Reply #6 on: February 02, 2013, 04:04:24 pm »
the winter 2012 edition of Model Boats had a build of a kit landing craft with an operable ramp door
Wayne
Pondweed
« Reply #7 on: February 09, 2013, 11:54:44 pm »
Wayne
How did they seal the door in a realstic and non-obvious way?
If feasible, I would copy how it operated in actuality. Or would go as far down that road as possible and with that in mind, there's an etch fret available for it. The metal parts may help with the hinges and pulleys/brackets you'd need if you mimiced how the real item operated, i.e. a cable pulling the ramp up.
http://www.bnamodelworld.com/index.php?main_page=product_info&products_id=20472
You may also need a bit of lead in the top of the ramp to help it lower itself under it's own weight while pulling the cable out of the craft.
The pivots on the ramp will be important as well.
murphy1570
« Reply #8 on: February 10, 2013, 12:27:53 am »
Hello again folks
T hanks for all tips to date, anymore help is allways welcome.
MarkScratchBuilt
« Reply #9 on: February 10, 2013, 12:43:32 am »
looks like this might have to be my next project!  :}
Page created in 0.207 seconds with 17 queries.
