Author Topic: z37 refit  (Read 4663 times)
SHADOWFLEET
  • 1/200th battleship-39 sunk september 2012
  • thank you for all you help an kind infomation
z37 refit
« on: February 03, 2013, 07:48:39 pm »
all ive done to the baot so far is do repairs an made the rigging an flags an painted 60% of the boat . re wired the boat an made charging points more easy without taking the batterys out . as this has four batterys
also has sound an soon to be lights an smoke
ships of my fleet in dry dock an builders dock
1/96th scale hms cossack>>building
1/96th scale km Z37 Narvik> refit
1/24th scale Vosper MTB>>building
1/144th USS casablanca Carrier>> shelf
1/96th Hms penalople>> shelf
Re: z37 refit
« Reply #1 on: February 03, 2013, 09:44:48 pm »
all ive done to the baot so far is ......
Well that sounds like a fair start ....  :}
Re: z37 refit
« Reply #2 on: February 03, 2013, 10:14:26 pm »
What batteries are in her?
SHADOWFLEET
Re: z37 refit
« Reply #3 on: February 03, 2013, 10:56:36 pm »
2300 lipo batteries x 2
2 x hytec gold speed controllers
1 receiver battery and 1 for sound
Re: z37 refit
« Reply #4 on: February 03, 2013, 11:06:30 pm »
Does she have any other ballast?
She must be an old build as the gold ESC's havent been made for some time.
SHADOWFLEET
Re: z37 refit
« Reply #5 on: February 03, 2013, 11:17:49 pm »
I canrt find any . So im thinking the motors an stuff inside is keeping the
Model up right . But ive noticed when opening up full throttle the boat rocks alot . So im thinking itz too high
In the water . I had add 45grams on one side to stop it leaning to the left
I mean she goes really fast .which is strange for a warship .
With the old speed controllers . Ive found that when i open the trottle up 2clicks itss
Going really fast . Could this be the old speed contollers ???
SHADOWFLEET
Re: z37 refit
« Reply #6 on: February 06, 2013, 04:35:18 pm »
Ok abit of a lose end . Ive got some 1.5mm leds an i want to wire them up tp my ship
 I have 5channel controller .
My channels are now taken up bar channel 5 . I dont really want to use a servo
But more like a switch . That  when i flick my swtich on my controller they stay on
Any ideas people
SHADOWFLEET
Re: z37 refit
« Reply #7 on: February 06, 2013, 09:03:25 pm »
one question i forgot to ask , will cyanocrylate  be ok to use on the fibre glass hull ??
Re: z37 refit
« Reply #8 on: February 06, 2013, 09:59:55 pm »
The 2 x LiPo batteries should be a bit light for her.
Might be worth cheching the waterline up to the top of the boot topping.
For this type and size of hulls I usually have enough draught to fit some sheet lead along the keel inside the hull.
SHADOWFLEET
Re: z37 refit
« Reply #9 on: February 23, 2013, 12:16:27 am »
has anyone know of a place where i can get detail parts for the Z37 .
and also im looking for pictures of the destoryer in colour as im thinking of a refit for it. as i look at it an still dont think
it looks right
hmsantrim
Re: z37 refit
« Reply #10 on: February 23, 2013, 04:25:10 am »
   Hi shadowfleet.
                             RE: Ive found that when i open the trottle up 2clicks its Going really fast . Could this be the old speed
                             contollers ??? . I mean she goes really fast .which is strange for a warship.
                            Erm Hello!!!   its a WWII german destroyer you have  its meant to go fast like 36Knots.  The battle ships are the
                            ones that  go a bit slower you have obviously not see a destroyer cut through the water.  A destroyer will heel over
                            when turning at speed.
                                With a narrow beam hull like this they are prone to a bit of rock n roll.  The general consensus is keep the top
                                 weight down, if used a lead acid battery should be placed flat.  You could always try fitting some rolled lead as
                                   internal bilge keels.
                             Its a Deans kit you have, contact  them for parts  There may  be some brass etch fittings for it now.
 click on these links it will keep you busy for quite some time.
 http://www.google.co.uk/search?sourceid=navclient&aq=&oq=german+Z+class+destroyer&hl=en-GB&ie=UTF-8&rlz=1T4GGHP_en-GBGB453GB454&q=deans+marine+z37&gs_l=hp..1.41l7.0.0.0.2377...........0.
  http://www.google.co.uk/search?sourceid=navclient&hl=en-GB&ie=UTF-8&rlz=1T4GGHP_en-GBGB453GB454&q=german+Z+class+destroyer
http://www.google.co.uk/search?sourceid=navclient&hl=en-GB&ie=UTF-8&rlz=1T4GGHP_en-GBGB453GB454&q=z+klasse++Zerst%c3%b6rer
                  Frank.  :kiss:
SHADOWFLEET
Re: z37 refit
« Reply #11 on: February 23, 2013, 07:20:48 pm »
thank you :D ill start painting it tomorrow
Page created in 0.011 seconds with 17 queries.
