Pages: [1] 2 3   Go Down
Author Topic: Hms cossack build started  (Read 16476 times)
SHADOWFLEET
  • 1/200th battleship-39 sunk september 2012
  • thank you for all you help an kind infomation
« on: February 07, 2013, 02:42:19 pm »
hi people to give a low down .im going to try an give a detailed build of this model an try an help future people build this model model more easy. ive had quite alot of respone an help to get a idea where to start . feel free to add opions in an hints an tips
i purchased a hms cossack off modeldockyard. from deans marine. with the motors an fitting kit . well today at 9am i started the build
firstly what needed doing is the line work at the top of the boat needed sanding all round
doing that an to find out where the line is . just above the plating is a line . you need to sand it too that line.  all around the boat
show im doing to show you the model all lined up an ready and half way through sanding
now the hull is sanded now after about 3 house of careful sanding
i then started sanding about a inch down from the top of the inside of the hull . this is too hel pthe wood stick
[URL=http://imageshack.us/photo/my-images/571/20130207135048.jpg/]
after this i then started to wash the hull down with warm soapy water an abit of jif cream . an rinsed the model down an wipe;t down then left to dry
[URL=http://imageshack.us/photo/my-images/832/20130207142246.jpg/]
. after three hours of letting to dry i  then started to draw the 2mm line down the hull
ships of my fleet in dry dock an builders dock
1/96th scale hms cossack>>building
1/96th scale km Z37 Narvik> refit
1/24th scale Vosper MTB>>building
1/144th USS casablanca Carrier>> shelf
1/96th Hms penalople>> shelf
Lash151
Re: Hms cossack build started
« Reply #1 on: February 07, 2013, 03:03:22 pm »
I am looking forward to watching your build... keep the pictures coming  :-))
Lee
SHADOWFLEET
« Reply #2 on: February 07, 2013, 03:05:30 pm »
the next step in the hull build is making a tool to draw your 2mm line . well simple way of doing it is
1x 15inch rule . cut 5mm off the ruler an then glue it 2mm away from the end of the ruler . the end you just cut . this gives you the 2mm line you need
well here is pictures of the finshed tool in action an all draw up
[URL=http://imageshack.us/photo/my-images/692/20130207145712.jpg/]
[URL=http://imageshack.us/photo/my-images/801/20130207145706.jpg/]
SHADOWFLEET
« Reply #3 on: February 07, 2013, 03:13:38 pm »
just remember at this point . every modeller makes mistakes . well i found my mistake . i forgot to smooth down a tiny part of the lip by the top deck . well as you can see my old line near the top. you can now see all smoothed down the new line .
that is this time . i throught time for tea an biccys . an a good look through the plan an detail sheet just to make shore i havent missed anythink out .
( an of course make the misses a cuppa . remember keep them sweet you get more time with your model an no hassle)
SHADOWFLEET
« Reply #4 on: February 07, 2013, 03:14:35 pm »
Lee
hi lee ill keep the pictures coming no worries on that
SHADOWFLEET
« Reply #5 on: February 07, 2013, 03:52:24 pm »
tea break over ive now start glueing some strips of wood to the 2mm line an carfully making shore its 2mm . as we dont want the deck raised or too low.
[URL=http://imageshack.us/photo/my-images/26/20130207154915.jpg/]
here also you can see a picture what i mean making shore its 2mm deep
steve pickstock
« Reply #6 on: February 07, 2013, 04:00:56 pm »
Looking forwards to this myself.
However question - why 15" rulers and not a cheaper 6"? But surely someone has designed a tool for this?
SHADOWFLEET
« Reply #7 on: February 07, 2013, 04:46:32 pm »
the more then likely have . but im doing this on the cheap. making the tools for the job. an buying them if need be on the cheap. one thing alot of modellers have told me specaily stan. you dont need all the high priced stuff. as you can buy it so much cheaper .
« Reply #8 on: February 07, 2013, 04:49:48 pm »
Guessing thats what he had to hand, or the 15" is wider
NFMike
    • Plague Marine Services
« Reply #9 on: February 07, 2013, 05:02:42 pm »
Hm. I think I shall be following this too as my next project (in about 3 years time  :embarrassed:  ) may well be something like this.
Yes indeed - nothing worse than tearing down work already done.
SHADOWFLEET
« Reply #10 on: February 07, 2013, 05:03:52 pm »
the part i was on about stan
Uploaded with ImageShack.us
SHADOWFLEET
« Reply #11 on: February 07, 2013, 05:13:09 pm »
is it what you mean by lining up the hull
Stan
« Reply #12 on: February 07, 2013, 06:03:44 pm »
Hi Shaddowfleet. I have no idea why this part should be like this. I have built a Deans Liberty Ship and Fletcher Class Destroyer but not a Cossack. I would recommed that you build a stand before you start construction making sure the stand sits on a level surface. Once the model is placed on the stand it can be checked for level using a small sprit level. A centre line will also help with construction. A visual check is good way of making sure construction is going alright, no levels or fancy tools for this operation just a good eye is all that is needed.  I have used these methods during the construction of my models over the years. The above items are for guidance only, if you have any doubt then contact the model supplier or kit manufacturer.
SHADOWFLEET
« Reply #13 on: February 07, 2013, 06:50:14 pm »
Have u got a
 pictures by any chance to get a idea what it means . Ive emailed deans marine qith photos and asking them for help
Stan
« Reply #14 on: February 07, 2013, 07:10:36 pm »
Check your build instructions. You should find details on how to make a stand for your model.
SHADOWFLEET
« Reply #15 on: February 07, 2013, 07:17:06 pm »
Ill have a look 2morro im shore there was somethink about it .
If not ill have to find a copy somewhere .
SHADOWFLEET
« Reply #16 on: February 07, 2013, 07:28:20 pm »
I have got a question . Do u mean a stand like the one my z37 sits on http://img72.imageshack.us/img72/5395/20130202213017.jpg
Stan
« Reply #17 on: February 07, 2013, 08:37:44 pm »
Yes
SHADOWFLEET
« Reply #18 on: February 07, 2013, 08:44:47 pm »
Brilliant . Well me an my dad are going to level the bench an then the jig . Like a real slip way.before anymore is built.
My father has look't at the pictures an is going to take measurments off the plans on width an see where is wrong
(Thank god )
pettyofficernick
  • Marineville will be destroyed, Muahahaha.....
« Reply #19 on: February 08, 2013, 12:12:46 am »
Hi there, slight distortion is quite common with F/G hulls, but easy enough to rectify, just pull the sides in when you fit the deck beams and all will be fine..... :-)) :-)) :-))
What I do is best not discussed, for I have been many things in my time....
SHADOWFLEET
« Reply #20 on: February 08, 2013, 12:32:42 am »
Hi there are you shore dude . Ive been thinking of
 taking measurments of the width of the hull plan to
Make shore im doing right . Me an my dad have been
 talking about the bow and thinking the bow is wrong
As kit of the front deck is wider then the open can open up.
Also this 2mm line you have to do . Ive put the woood where
Its ment to go . But im baffed how the deck template an deck is
Ment to fit in 2mm depth an lay flat an level againist the hull
« Reply #21 on: February 08, 2013, 01:11:34 am »
I think I''ll tag along with your Cossack build ..... O0
SHADOWFLEET
« Reply #22 on: February 08, 2013, 04:26:58 am »
How silly ive been the tribal class destoryers one remains to
This day . Hmcs haida . Atleast now i will be able to get more research
Done
pettyofficernick
« Reply #23 on: February 08, 2013, 09:53:10 am »
Goos morning Shadow. With most Deans kits a little 'tweaking' is required with templates and plastic parts. best to cut everything out over size and then fettle them to fit, it tells you this on the general instructions page in your kit instructions. Just remember to shape the decks evenly on each side, otherwise the openings for the superstructures will be off centre. Have a look at Deans Marines forum, there are several build logs of their warship kits, not much on Cossack, but plenty on similar kits, all seem to encounter similar problems to yourself. The HMS Solebay being a case in point.  http://www.deansmarine.co.uk/index.php?topic=427.0   as the bloke building it says, Deans kits are 'modelers kits', with most of the printed plastic parts needing adjustment to obtain a good fit. The HMS Kelly build thread also flags up similar problems   http://www.deansmarine.co.uk/index.php?topic=227.0. Also, the plans will vary in size slightly depending on temperature and humidity, for example, on a warm, dry day, a part may measure out at say, 150mm, on a cold damp day, the same part will measure out at say, 152mm. So basically, you will have to make compromises as your build progresses.....
SHADOWFLEET
« Reply #24 on: February 08, 2013, 05:03:29 pm »
as anyone got the stand build sheet ???? for the hms cossack
Pages: [1] 2 3   Go Up
Page created in 0.094 seconds with 21 queries.
