Author Topic: Brushless for a tugboat?  (Read 3376 times)
Tbone
« on: February 16, 2013, 06:51:32 am »
Building a dual motor tugboat and not sure about motor selection.  Any advice on where to start?
Plan to run the boat on 3s lipo power.
Re: Brushless for a tugboat?
« Reply #1 on: February 16, 2013, 08:16:32 am »
what size is the tugboat?
Tbone
« Reply #2 on: February 16, 2013, 12:43:59 pm »
I think it's about 31 inches, it's the Model Slipway Al Khubar
Umi_Ryuzuki
    • Models and Miniatures
« Reply #3 on: February 16, 2013, 05:57:24 pm »
Graupner was spec'g
Nominal voltage: 14.8 V
 Operating voltage range: 7.4 ... 18.5 V
 No-load speed: 13,320
 Revs. / Volt (kV): 900
 Permissible motor direction: R and L
 Case length excl. shaft approx. 46 mm
 Diameter approx. 35.2 mm
Free shaft length approx. 18 mm
Leen Boers has some G46 brushless in his Maersk Topper, the
KV rating he used was 420 for main drive.
I would think that you still need the ballast for
a boat the size of Al Khubar, couldn't you just use Gel Cells?
Tbone
« Reply #4 on: February 16, 2013, 06:31:03 pm »
I could use gel cells but have lipos already. Gel cells are still an option. I want to make sure that whatever I put in will do what I need.
Umi_Ryuzuki
« Reply #5 on: February 16, 2013, 06:59:38 pm »
Leen Boer's Maersk Trader
http://www.youtube.com/watch?v=M8qLfGcUZcw
 8) 8) 8)
« Reply #6 on: February 16, 2013, 09:56:02 pm »
Now that is a seriously smart build!
nick_75au
    • Logan City Marine Modellers
« Reply #7 on: February 16, 2013, 10:16:27 pm »
I would use either a 28 mm out-runner rated at less than 1000 Kv and on 6 volts or DT700-700Kv which could run 12 volts (but a little throttle control needed) Im assuming the props will be around the 40 mm size, if they are smaller then either the voltage or Kv could be raised slightly.
Nick
M.Topper
« Reply #8 on: May 11, 2013, 04:45:38 pm »
Hello Tbone ???
I made some months ago the first test sail with my new model of the Maersk Topper.
For all propulsion I use brushless motors.
For the bow (48MM) and sternthrusters (38MM) I use HK Turnigy XP 28 outrunners (750kv) and for the main (working) CPP (80mm) I use HK G46 motors.
In the first test the main brushless motor are so powerfull that the port CPP blocked in max pitch.
At the Dutch Working ship meeting last thursday it was teh second test, and after some starting problems the test was very succesfull.
Thr brushless motor are very powerfull, and after some modivications at the max turn of the blades , still the model is much to fast.
Understanding some videos of the test sail:
https://www.youtube.com/watch?v=M8qLfGcUZcw
https://www.youtube.com/watch?v=vsK3ZsVQFdM
https://www.youtube.com/watch?v=V3O_gTHaTiM
https://www.youtube.com/watch?v=Q4S4MXj3NZI
Some photos of the Dutch Working ship meeting,
