Author Topic: Timber for mast  (Read 3470 times)
Brian60
Timber for mast
« on: February 22, 2013, 06:51:27 pm »
Which timber would be the best/strongest to use for a mast? The dimensions are approx 12mm diameter to 8mm diameter over a length of approx 32cm.
I was also thinking of making this up from 4 square pieces glued together before shaping, the reasoning being I could plane off an internal angle from each piece before gluing to run the rx aerial up the centre, your thoughts please........
Re: Timber for mast
« Reply #1 on: February 22, 2013, 07:17:53 pm »
I think it is spruce that has been reccomended in the past but will stand corrected if I am wrong
steam up
Re: Timber for mast
« Reply #2 on: February 22, 2013, 07:44:44 pm »
Try lemon wood or have a look for an old snooker cue from the car boot sales.
Re: Timber for mast
« Reply #3 on: February 22, 2013, 08:07:46 pm »
What is it for?
Only a foot long and half an inch
thick at base
A sail on that would not be very big.
mrpenguin
Re: Timber for mast
« Reply #4 on: February 22, 2013, 10:23:28 pm »
If you are using 2.4GHz radio there is no need for a long aerial (up the mast or whatever), will most likely be Ok below deck unless the boat is all carbon fibre....
Amateur at work...
hammer
Re: Timber for mast
« Reply #5 on: February 22, 2013, 10:33:47 pm »
Straight grain is important, laminating will avoid this problem.
Re: Timber for mast
« Reply #6 on: February 23, 2013, 12:47:35 am »
Hardwoods tend to be brittle, and are more prone to snap.
Woods that have some give, like most softwoods, are suitable.
Brian60
Re: Timber for mast
« Reply #7 on: February 23, 2013, 07:59:10 am »
What is it for?
thick at base
Its a two piece mast on a sailing trawler.
The radio system is a cheap 40mhz set I bought for this project and while I've had no problems with thus type of set in the past with large grp hulls, this one is only around 18-24 inches long, so wanted to give the aerial the best chance by running it hidden up the mast.
So the concensus is to go for a softwood and my laminating it together is the best for strength. I'll see what the local timber shop can offer. I've bought a nice oak plank that is going to be ripped down to make the hull planking with, thats another story of steaming and bending.
steam up
Re: Timber for mast
« Reply #8 on: February 23, 2013, 10:02:36 am »
If possible I would keep clear of oak it is very open grained at this scale making a nice finish difficult to achieve.
Cherry is a much better choice.
hammer
Re: Timber for mast
« Reply #9 on: February 23, 2013, 06:05:45 pm »
I will agree with that Oak can also be very unstable. Even if well seasoned when its worked it can move.
Brian60
Re: Timber for mast
« Reply #10 on: February 23, 2013, 06:47:02 pm »
Guys you've made a grown man cry, I paid 20 quid for my piece of oak! Now it seems I have to go and spend some more! {-)
hammer
Re: Timber for mast
« Reply #11 on: February 24, 2013, 10:41:20 am »
Don't cry. I am sure you will find ause for it one day. I have tried to post aphoto of my trawle..Geoff
Brian60
Re: Timber for mast
« Reply #12 on: February 24, 2013, 01:27:32 pm »
I've got to say Geoff that you posted some pics of her before and it inspired me! After I've almost completed my small grp hulled effort, I realised there would not be enough freeboard for it to sail anywhere but in the bath. So I'm making the effort to build a larger more seaworthy one in timber, hopefully I can get somewhere near the standard of yours.
