I don't like the yards attached/mast rotate method. Standing rigging must be heavily modified to accommodate the rotating mast. Plus, it's not at all realistic, if that is an interest of yours.
It's relatively easy to RC a kit using dowels for masts and yards, and simple screweyes for the yard hangers. The yards are then swung with braces, either using standard aircraft servos (the Parallelogram method), or with winches. Winches are more complicated and expensive, but provide realistic running rigging. The simpler parallelogram method uses cheaper servos, and is easy to debug, at the expense of some realism. At 50' offshore, both methods look about the same.
eg of my screweye method, post#27
http://www.rcgroups.com/forums/showthread.php?t=1071509&page=2eg. of a successful 1:96 scale plastic USS Constitution conversion for square-rigged RC sailing:
http://www.rcgroups.com/forums/showthread.php?t=1417997Any of Meatbomber's threads would give you good advice, also.
Here he converts a wood scale model Brigantine to RC:
http://www.rcgroups.com/forums/showthread.php?t=1174628My 1st squarerigger was Pamir (she started as a free-sailer, then was converted to RC). You might find helpful information on this thread:
http://www.rcgroups.com/forums/showthread.php?t=743611Welcome to the world of RC squareriggers, they are lots of fun
