Author Topic: Building boards ?  (Read 3237 times)
portside II
  • tugs at rest
Building boards ?
« on: February 27, 2013, 10:13:10 pm »
Having never used a building board or even owned on i thought it was about time i got one and started building propper boats, not that my springers and barges arn't propper boats , it's just that they are box builds.
So what do you use , a commercialy available one , or something you have built yourself. Is there a set spacing for ribs and attaching them to the board.
So come on lads and lasses piont us in the right direction.
daz
Howard
Re: Building boards ?
« Reply #1 on: February 27, 2013, 10:19:02 pm »
What you going to build Daz.
the sea helper?
            Regards Howard.
hammer
« Reply #2 on: February 27, 2013, 10:37:29 pm »
You need to go to your nearest recycling centre. An older 40s to 60s wardrobe made from block board door.  This will be the most stable, better than solid timber or chipboard. you can shorten it or build a boat up to 6 feet long.  Who knows you may get some useful ply from it as well.
« Reply #3 on: February 27, 2013, 10:39:09 pm »
All you need is a flat board, that will saty flat. I use 20mm MDF, Rib spacing depends on the size of boat and the curvature of the hull (stem to stern). Ribs are attached to blocks screwed to the board. Usually the ribs are cut to give a tongue which ensures that they all sit at the correct height above the board and that you are not planking up/down to the board.
Hope this makes sense.
david48
« Reply #4 on: February 27, 2013, 10:56:23 pm »
 good evening  I made my building board out of piece of kitchen worktop its a bit thick ,i found this helped .I used it upside down,good to mark out on because it is paper backed and stuck some rubber strips on the pattern side to stop it sliding about .Its is a bit weighty this helps keep my model still on the bench.I use it to build Billings Fairmount Alpine
« Reply #5 on: February 28, 2013, 12:49:05 am »
I think it is possible to get hung up about building boards. It is easy to forget that we are working with wood, and not precission engineering and working in thou. Any flat, stable board will work.
Making sure that you set up the the frames square and true, is just as important as having a flat stable base.
portside II
  • tugs at rest
« Reply #6 on: March 01, 2013, 12:39:41 am »
the sea helper?
            Regards Howard.
No way Howard , i have seen it under construction at Pete's , and it is looking well  ok2 .
Cheers guys , i have been offered either a 2x4 (i build big boats) :-)) sheet of MDF 18mm , or a length of worktop .
And going by the replies i am on the right track , i just need to get some PSE 2x1 which should do for the rib spacers,
as these are true square they will be vertical .Good idea about the tounge to stand the hull off the board.
I will get some pics up once i have got the material sorted and assembled.
daz
« Reply #7 on: March 01, 2013, 08:10:50 am »
I have the Billing boats building slip but I have never used it as the boats I have been building won't fit
Page created in 0.039 seconds with 21 queries.
