Pages: 1 2 3 4 [5]   Go Down
Author Topic: True C/V joint.for our boats  (Read 30997 times)
tt1
Re: True C/V joint.for our boats
« Reply #100 on: June 01, 2013, 04:50:49 pm »
Congratulations on a magnificent achievement Mick. O0  Such a compliment from the ex Action man himself is praise indeed and I'm really pleased for you to have achieved such a successful out come for all your endeavors - well done to you!! :-))
           Right! ---------------- now how much are they including postage to the uk??
                                               Kind regards, to you and Phyllis, Tony.
« Reply #101 on: June 01, 2013, 05:43:56 pm »
2nded only but to sunny Finland (27c today)
When does the order book open?
irishcarguy
« Reply #102 on: June 01, 2013, 08:18:58 pm »
Thank you Dave for the kind words. It started life as an axle made by HPI racing but they just did not want to bother with a little guy like me & just brushed me off with my design conversion.I have sent two to England to two friends that I knew would give me an honest opinion warts and all. It is not my intention to produce them for sale, the sole intent was to make something to put that dreaded Huco to shame. Most of you know that the two guys I trusted  to test it was Dave Martin (  Norseman) & Dave Milburn ex ACTion guru. However I have gained several good friends on this forum & would be happy to make one for you at dead cost. One axle is $20.00 (two in a packet, $40.00 ) & posting was $10.00, total $30.00 or about 20 pounds each. Tony & Essex I have you on my list & will make one for each of you, but I require measurements as each is custom made to fit your motor & shaft. We can talk later through PM. A final note if you want to make your own it is not hard but you do need the best drills,taps & dies. PM me for details. Mick B.
Mick B.
« Reply #103 on: June 02, 2013, 06:56:09 pm »
Tony I can oversee the job for you in August, but I can't however guarantee Mick's sobriety level as I intend to be a thoroughly bad influence on him. ... CV joint really is a nice piece of kit and is crying out to be manufactured commercially  O0
destroyer42
« Reply #104 on: June 02, 2013, 07:25:34 pm »
Hi All,
I alway's use either the Robbe or Graupner direct coupling,not only does it align your shaft and motor it's simple and keeps the torque.
Destroyer42
« Reply #105 on: June 02, 2013, 11:17:35 pm »
destroyer42 ...I have checked the WEB....could you please post a link to either the Robbe or Graupner direct coupling you mention...I am after 4 mm x 4 mm rigid or fixed coupling ......thanks Derek
RAAArtyGunner
« Reply #106 on: June 02, 2013, 11:33:47 pm »
Yes please  :-)) :-))
irishcarguy
« Reply #107 on: June 03, 2013, 03:13:53 am »
Hi Guys I made a full set of fixed couplings on my lathe which I use to initially align the motor & propshaft. I then enstall my C/V joint. I should point out that even if you use a solid connector to align the shafts, when you tighten the bolts/nuts on the motor mounts it will distort somewhat & you are well advised to install a joint to correct any possibility of misalignment.Mick B.
Mick B.
destroyer42
« Reply #108 on: June 03, 2013, 06:55:23 pm »
Hi All,
I use either the Robbe or Graupner straight rigid couplings, never had any problems and the motor/prop shafts run true and straight. I run some torque motors on my models all geared either Robbe or Graupner, I have never found better motors.
You will soon know if you have misaligned it when fitting you will see it.
http://www.cornwallmodelboats.co.uk/acatalog/couplings.html
Destroyer42
« Reply #109 on: June 04, 2013, 01:14:38 am »
Thanks destroyer42........when I searched for Graupner shaft couplings all of the usual Huco style & dog+bone style appear.... but not rigid couplings
When I search for Graupner 3382 couplings.....BINGO......they appear  :-))  .....Derek
Pages: 1 2 3 4 [5]   Go Up
Page created in 0.223 seconds with 17 queries.
