Author Topic: Shottle Drives  (Read 7873 times)
adamD98
  • Born free, forced to work!
Shottle Drives
« on: March 06, 2013, 05:04:14 pm »
Hi all,
 As some may know i'm planning a new build - however I believe the original tug has Shottle units...
Are these ok for Tug towing on a model? If so - which units would "you" recommend I use?
Thanks in advance as usual  :-))
Cheers,
-Adam-
tugboyben
  • Kirkleesmodelboatclub
  • WARRIOR TUG BOAT
Re: Shottle Drives
« Reply #1 on: March 06, 2013, 05:32:49 pm »
Adam
There is a brand new pair on Ebay now not cheap
http://www.ebay.co.uk/itm/170996388654?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I got a brand new pair last year form gliders 99.99 each then you need high torque servo's around the 20-25 mark then motor's  %% %% %% %% %% [size=78%] [/size]
http://www.gliders.uk.com/prodinfo.asp?number=G2335
good look with the new build
Jason
F4TCT
  • I am not completely useless.......I can always serve as a BAD example
    • My Boat Builds
Re: Shottle Drives
« Reply #2 on: March 06, 2013, 06:02:33 pm »
for the price of the ones on fleebay, you may aswell buy these - http://www.cornwallmodelboats.co.uk/acatalog/graupner_2335.html
Ive heard that these suffer with the plastic gears in them and they also leak.
I fancied a pair aswell but I think i'l go for steerable korts.
catengineman
Re: Shottle Drives
« Reply #3 on: March 07, 2013, 12:22:49 am »
My Tito Neri has a pair of the drives from Graupner, I can say that I have not had problems with leaks and mine have brass gearing inside.
you do need very strong servos to keep them from locking or turning with the torque of the props. I have also converted mine to brass propellers which give even more 'kick' to the unit.
these units have been in three tugs which I have had or worked with and only one had plastic gearing and that was an old model.
Umi_Ryuzuki
    • Models and Miniatures
Re: Shottle Drives
« Reply #4 on: March 07, 2013, 03:35:07 am »
The small Schottle handle the boat and tow very well.
10kg barge to 400kg pumpkins...
adamD98
Re: Shottle Drives
« Reply #5 on: March 07, 2013, 09:19:35 am »
Thanks folks  :-))
 I'm really tempted to go with Shottles - I'm just worried as I say about doing a lot of Tug Towing and either burning them out or chewing gears up.  :o
hmmm...  :-)
Cheers,
-Adam-
F4TCT
    • My Boat Builds
Re: Shottle Drives
« Reply #6 on: March 07, 2013, 10:08:57 am »
i've just ordered an FT-X from Mobile Marine Models and i mentioned to brian that i was thinking of having some very expensive 100mm wide kort units made for me. He said thats all well and good but we have tested such things and you simply dont get the thrust from the units like you would a steerable kort so i went for the steerable korts in the end although I would much prefer the schottels.
Dan
ministeve
  • washing the decks!!!
Re: Shottle Drives
« Reply #7 on: March 07, 2013, 11:18:31 am »
that is right Dan but you can not go 90 deg with Kort's but don't norm need to  specially if bow thruster is fitted
F4TCT
    • My Boat Builds
Re: Shottle Drives
« Reply #8 on: March 07, 2013, 11:25:57 am »
The FT-X will have bow thrusters and steerable korts. that should be enough for what I want.
I would love the schottels though  {:-{
adamD98
Re: Shottle Drives
« Reply #9 on: March 07, 2013, 12:18:24 pm »
I'm going to go with conventional Prop shafts with steerale korts. As you have said F4TCT - i'd love to put shottles in, but I know where I am with the conventional method. Now - what size Korts for the Svitzer Maltby - hmm  {-)
Cheers,
-Adam-
F4TCT
    • My Boat Builds
Re: Shottle Drives
« Reply #10 on: March 07, 2013, 12:22:09 pm »
lol, well its a shame they are so expensive otherwise it would be worth having a go with them.
I guess it depends on what you want to do with the tug, serious heavy towing and they may not be able to handle it for long. They look nice and function nice for gentle sailings on the pond.
Im no expert, quite the opposite.
Dan
adamD98
Re: Shottle Drives
« Reply #11 on: March 07, 2013, 12:25:57 pm »
Exactly my thoughts - they look great and give good performance on the water, but for constant towing, i'm not sure it's worth the risk considering the cost of the units. Expensive to replace.
Cheers,
-Adam-
F4TCT
    • My Boat Builds
Re: Shottle Drives
« Reply #12 on: March 07, 2013, 12:29:48 pm »
Im not slating the product or anything, just purely what ive read from others experience using the schottels has put me off buying them.
Dan
adamD98
Re: Shottle Drives
« Reply #13 on: March 07, 2013, 12:32:59 pm »
Oh I agree - I've seen various makes of shottle, all of which were impressive. But they were used on boats that don't require nor use a lot of torque. Simply just to have a steady sail.
 I suppose using them on an Anchor handler or Platform supply vessel would be ideal, as most of the recent Offshore vessels are run on shottles I believe. Future projects!  O0
Cheers,
-Adam-
poll
Re: Shottle Drives
« Reply #14 on: March 07, 2013, 01:45:11 pm »
Hi Adam.
I think it's time for you to make a trip to Balne Moor mbc on a towing day, To see the shottle drive tugs manouver 300LB tankers round a course with no problem. Tugs you see are Flying Kestrel & Osprey.
adamD98
Re: Shottle Drives
« Reply #15 on: March 07, 2013, 01:50:29 pm »
 :-))  Thanks John. I'm more than happy to have a run over to Balne Moor mbc. Just give me the dates your sailing and i'll make sure i'm there!  O0
 It would be good to be put at ease over Shottles before I start the new build.
Cheers,
-Adam-
poll
Re: Shottle Drives
« Reply #16 on: March 07, 2013, 02:11:57 pm »
  Hi Adam.
  You will find all the dates for 2013 on our web site,  Balne Moor model boat club. I think a lot of modellers
  think you have to tow at 100mph  ha ha  but that's not the case.
adamD98
Re: Shottle Drives
« Reply #17 on: March 07, 2013, 02:16:51 pm »
 {-) :-))  Thanks John - yeah I got my first taste of Tug Towing over at Ellesmere on Saturday with my Eldergarth. Thoroughly enjoyed it. I have no idea if I spoke to you or not!  :embarrassed: {-)
Cheers,
-Adam-
adamD98
Re: Shottle Drives
« Reply #18 on: March 07, 2013, 02:20:49 pm »
April 7th ? ... that's a certain someone's Birthday!  O0 :embarrassed: ;D  - I don't think SWMBO would be to happy with yours truly!
Cheers,
-Adam-
poll
Re: Shottle Drives
« Reply #19 on: March 07, 2013, 03:27:41 pm »
  Hi Adam.
  Bring her with you, tell her it's her Birthday but your choice to where you go :-))
adamD98
Re: Shottle Drives
« Reply #20 on: March 07, 2013, 03:30:10 pm »
Oops - I actually meant it's my birthday  :o %)  not her's - but she'll have planned something no doubt!
Cheers,
-Adam-
Big Ada
Re: Shottle Drives
« Reply #21 on: March 07, 2013, 04:05:10 pm »
Like Tiling the Bathroom?   %) %) %) %) %% %% %% %%
cos918
Re: Shottle Drives
« Reply #22 on: March 07, 2013, 04:27:07 pm »
adamD98
Re: Shottle Drives
« Reply #23 on: March 07, 2013, 09:24:56 pm »
I'll try and get the day off - i'll move my Birthday (can you do that? I mean, it does belong to me after all!).
Thanks for the link John  :-))
Cheers,
-Adam-
bigford
Re: Shottle Drives
« Reply #24 on: March 08, 2013, 04:27:48 am »
i have two of these for a tug i'll be building someday
there the z deives for the seabex one
