Author Topic: Shottle Drives  (Read 7747 times)
adamD98
  • Born free, forced to work!
Re: Shottle Drives
« Reply #25 on: March 08, 2013, 06:44:59 pm »
Thanks bigford - always liked the Seabex One
Cheers,
-Adam-
adamD98
Re: Shottle Drives
« Reply #26 on: March 14, 2013, 10:08:19 pm »
Ordered myself a set of Schottel's  :-))  Looking forward to the new challenge when my Hull etc are ready.
 Going to use Graupner 900's on the schottel's, but I'm a little confuddled over which servo/s I should use, and "how" to set this lot up!!
I prefer Hitec servo's, just not sure what size/weight I should use.
Cheers,
-Adam-
Umi_Ryuzuki
    • Models and Miniatures
Re: Shottle Drives
« Reply #27 on: March 14, 2013, 11:12:54 pm »
If you are running the larger Graupner Schottel drives, Gr2335, then you will
want to run some high torque metal gear servo. Especially with the 900 motors.
If you don't, the motors will sometimes overpower the servo, and spin torque them out of position.
Also, build a small wood gallows for the shaft support ahead of the drive.
The motors will have a tendancy to torque those supports back and forth till they break.
adamD98
Re: Shottle Drives
« Reply #28 on: March 15, 2013, 12:04:55 am »
Thanks Umi  :-))  Advice most definately taken on-board. Those are the Schottel's by the way - the Gr2335 unit's.
Cheers,
-Adam-
catengineman
Re: Shottle Drives
« Reply #29 on: March 15, 2013, 07:14:17 pm »
There are a couple of modifications you can do which I have found to help in my Tito Neri and also on another tug that used them.
if you look at Umi's picture where the red is marked there is a small lube hole which I glued a tube to so that I could iol the bearings which are in that part.
then there is also another small orafice at the base where they are screwed to the hull of the vessel, this one I use to fill the stock with chain grease that then stops any water getting through.
this mod also has another small addition that I carried out ad to explain I will try. this allowes the grease can get to the drive shaft and therefore the 90* gear train in the hub.
Before I fitted the units to the hull I stripped them down to remove the drive shaft from the vertical, then with a small drill I made a hole through the internal part of the stock but before I did I made sure that the internal part was 180* from its normal position so that when the stock is in the normal position the hole I drilled was not in line and thus reduce the possibility of water getting through but also letting the grease to find its way to the drive train when I turned the unit as far as possible when I used the chain lube can.
adamD98
Re: Shottle Drives
« Reply #30 on: March 17, 2013, 07:43:27 pm »
Thanks for the tips catengineman  :-))  I guess being able to "service" the schottels, you certainly lengthen/maintain a good working life from them.
Cheers,
-Adam-
adamD98
Re: Shottle Drives
« Reply #31 on: March 19, 2013, 03:58:03 pm »
Just taken delivery of my Schottel's  :-))  Looking forward to this new challenge!
Cheers,
-Adam-
ministeve
  • washing the decks!!!
Re: Shottle Drives
« Reply #32 on: March 19, 2013, 06:59:44 pm »
take lots of pics adam will be watching with interest
regards steve
adamD98
Re: Shottle Drives
« Reply #33 on: March 19, 2013, 07:02:47 pm »
 :-))  Will do Steve - I'll start a build thread for the boat in question when I've got all the bits I'm waiting for.
Cheers,
-Adam-
old shrimper
Re: Shottle Drives
« Reply #34 on: March 21, 2013, 08:58:27 am »
keeping my eye on this one
i would like to put a pair of 70mm [/size]schottels, in to the AMSTERDAM is it poseable do you think ??
50 YEARS OF TOWING NETS
poll
Re: Shottle Drives
« Reply #35 on: March 21, 2013, 07:36:24 pm »
i would like to put a pair of 70mm schottels, in to the AMSTERDAM is it poseable do you think ??
 Hi old Shrimper.
 I don't think that hull lends it's self to shottles, It's a lot of cash to spend to find you have difficutly fitting them.
tugboyben
  • Kirkleesmodelboatclub
  • WARRIOR TUG BOAT
Re: Shottle Drives
« Reply #36 on: March 24, 2013, 06:02:10 pm »
Z drive's
Look to work very well running of brushless
I have some spare brass bevel gear's may i have a go at making one for a springer tug
http://www.youtube.com/watch?feature=player_embedded&v=TcMo8JyoXfk#!
Jason
adamD98
Re: Shottle Drives
« Reply #37 on: March 27, 2013, 12:33:39 pm »
...Guess what folks  :o :}  ... I've got my Maltby hull  O0 :}   :-)) !
 Got the Hull, plans and photo's. A pair of Schottel's and a load of timber! ...Now I need everything else!  O0 {-)
Cheers,
-Adam-
freshfrenchbread1964
Re: Shottle Drives
« Reply #38 on: April 08, 2013, 02:42:32 pm »
Adam Adam Adam!! where art thou Adam?  thought you were coming to Balnemoor yesterday ? All the countries top tuggers assembled in one place awaiting the final piece of the jigsaw. would her indoors not let you out to play on your Birthday?. Missed a great day , the sun was shining, the tea and coffee were flowing . The greasy bacon and egg sandwiches were been devoured & let's not forget the beautiful home made cakes made by Olive's daughters were sublime. The Tugs were towing ,  boats of all sizes were chug chug chugging  round the scale course . but where was Adam  ? My guess is you were building the Switzer Maltby  in secret ! lets have some pictures !your posts have dried up like an old prune (smiling ) hope to see you at the next one .
Nick
