Pages: 1 2 3 4 [5] 6   Go Down
Author Topic: My African Queen!  (Read 53782 times)
pettyofficernick
Re: African Queen started at last....
« Reply #100 on: May 25, 2014, 04:41:18 pm »
Why thank you Cal, I always think my efforts are a little rough when compared to others whose boats we see on these pages.....
pettyofficernick
« Reply #101 on: May 28, 2014, 05:43:36 pm »
The after section of oak decking is now more or less finished, just needs a lick with the sander to tidy it up. I have started setting out the bench seats and fixed the bottom rails down. I have also made a pair of ribs from brass angle and added the brass knees which will support the mahogany deck. Bending the brass angle was easier than first anticipated, so about 30 to go now. Progress is slow and painful at the moment due to being tormented by gout in my right hand, it is a case of do 10 minutes, rest for 10 minutes......
Bench seats bottom rails fixed
Rib and knee detail
Pair of ribs temporarily in place
pettyofficernick
« Reply #102 on: May 30, 2014, 08:11:18 am »
Here's a few photos of last nights efforts, this is the seating arrangements, the battery and receiver will live here. Two slight problems to overcome, 1, there is not enough room for the Rx ariels on the Futaba  reciever to be set fully at 90 degrees, and I forgot to put provision for the servo cables to be fed in, due to the revised layout after abandoning the Bowden cable control system.......
SailorGreg
« Reply #103 on: May 30, 2014, 09:03:33 am »
Coming along nicely Nick  :-))
Greg
pettyofficernick
« Reply #104 on: May 31, 2014, 08:50:52 am »
The oak planking inside the hull is now finished, apart from a bit of fettling with the sander, the section on the Port side lifts out for access to the water filter. Once the engine bay is painted, the next job is to fit the brass ribs and knees.....
pettyofficernick
« Reply #105 on: June 02, 2014, 09:46:50 pm »
Cross beams to define deck opening now fitted, made from ramin and faced with Mahogony. First side has been fitted out with 1/4 x 1/4 brass angle ribs.....
Apologies for poor photo, this particular camera does not seem to like tungsten lighting, even with the flash.....
muleears
Re: My African Queen!
« Reply #106 on: June 02, 2014, 11:23:46 pm »
Looks great to me Nick. I always learn something when I look at your stuff!
Does your camera have a "white balance" setting?  That would help with the color under tungsten lights.
Cal
Washington, NC USA
Proud owner of:
75% complete Krick Victoria
75% complete Billing African Queen
Krick Alexandra
Lots of building, very little steaming!
southsteyne2
« Reply #107 on: June 03, 2014, 08:57:35 am »
Looking good have you given thought about possible steam problems with servos as they may need some sort of shielding %) silicone comes to mind
pettyofficernick
« Reply #108 on: June 03, 2014, 09:23:01 am »
The servos will be hidden beneath Gin crates, I was planning on lining them with polythene to keep any steam off. However,  there won't be any steam leaks (he said, with fingers firmly crossed).....
pettyofficernick
« Reply #109 on: June 04, 2014, 07:04:12 pm »
All ribs and knees now fitted, bit of a milestone in the build, just the deck to go on now, but awaiting the skin fitting for the feedwater by pass from the machine shop, so I will start making gin crates, dynamite boxes etc and finishing seats off.
SailorGreg
« Reply #110 on: June 04, 2014, 09:52:47 pm »
muleears
« Reply #111 on: June 04, 2014, 09:57:35 pm »
Looks great Nick!   :-))
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
raflaunches
  • The Penguins are coming!!!
« Reply #112 on: June 04, 2014, 09:59:21 pm »
That looks really smart Nick, stunning work! :-))
Nick B
Illegitimi non carborundum!
pettyofficernick
« Reply #113 on: June 06, 2014, 07:29:39 pm »
After  spending most of the dat beavering away, sawing, sanding and getting thoroughly itchy from mahogany dust, the deck is now fixed in place, made from 2 1m lengths of 100 x 2mm monogamy sheet. Rather than use a third to make up the width, I roughly cut out the opening and glued the resultant strip on the outside with aliphatic resin, this was left overnight to cure. It was then a simple matter of clamping the first piece in place and drawing around the outside of the hull and cutting out with the trusty old Dremel scroll saw. I then used a combi square as a gauge to mark the inside edge, after cutting out, leaving a bit over for fettling later, it was glued in place with 1/2 hour epoxy. Same procedure followed for the other side, after a nice brew, clamps off and attack with the sander.....
pettyofficernick
« Reply #114 on: June 08, 2014, 12:10:51 am »
Well that's the deck finished, starting to look something like now.....
Bernhard
« Reply #115 on: June 08, 2014, 05:24:44 pm »
 :-)) Super-Duber.looking good
muleears
« Reply #116 on: June 08, 2014, 05:39:48 pm »
The brass ribs add a lot.  After a bit when they begin to tarnish, they'll add to the "tattered" appearance your looking for!  Should be a museum piece when you are done.  Just like in the movie! :-)) :-))
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
pettyofficernick
« Reply #117 on: June 08, 2014, 05:54:56 pm »
I am actually going to paint the brass ribs, the originals are iron/steel, so paint then rust. A little AQ trivia now. The African Queen was originally built on the banks of the  Ribble, near Lytham UK by the Lytham Shipbuilding and Engineering Company.
 Previously known as Richard Smith and Co the Lytham Shipbuilding and Engineering Co was set up in February 1894. It was based on the Ribble estuary to the East of Lytham at Lytham Creek.
During the 1800s the yard made shallow-draft river craft which were sent in pieces and rebuilt at their destination. In addition, the yard made a variety of sternwheel, quarterwheel and tunnel propulsion river boats, barges and tugs. She was named SL Livingstone and was shipped to The East African Railway Company company on the Victoria Nile and Lake Albert. Lake Albert is located on the border of the Belgian Congo and Uganda. She was built in a narrow way to navigate this river and was used to carry mercenaries, missionaries, cargo and hunting parties on their voyages.
In 1951 John Houston commissioned her in the starring role in a film he was making called The African Queen.
More information here   http://africanqueenflkeys.com/history.html She has now been restored and earns her living running canal trips around the Florida Keys.
muleears
« Reply #118 on: June 14, 2014, 01:57:18 pm »
How comes the Queen Nick?  You've been quiet lately.  Are you moving into your new shop yet?
Cal
Washington, NC USA
Proud owner of:
Krick Alexandra
pettyofficernick
« Reply #119 on: June 14, 2014, 03:56:55 pm »
A quick update, it is now time for painting, well, I hate paint, I hate painting, and I am definitely not a painter, so I immediately put it off and made some crates, all made from individual planks, 2 for the servos, 1 open one for the gin (any ideas where I can get 1/10th scale gin bottles?) and one to cover the flywheel. once these were done, I bit the bullet and slapped a bit of paint on the inside, doesn't look too bad from the other side of the room, but I guess it doesn't really matter as I am going for the shabby look anyhow.
« Reply #120 on: June 14, 2014, 11:36:35 pm »
Nick....stain the wooden crates with an off brown/blackish tone........then spray with matt polyurethane [inside & out]....I am also not a painter   >>:-(
But why would you need to cover the flywheel?................Derek
pettyofficernick
« Reply #121 on: June 14, 2014, 11:52:01 pm »
The box over the flywheel is where Rose and Charlie brew up, and where Charlie stood his Gin mug, before Rose threw it all overboard....I will be staining the crates and putting Gordons labels on them......
« Reply #122 on: June 15, 2014, 09:34:52 am »
Probably Dolls House wine or spirit bottles in 1/12 if they don't look too much out of scale.
pettyofficernick
« Reply #123 on: June 19, 2014, 08:30:18 am »
I have been looking at 1/12th scale bits and pieces, I don't think they will look out of scale, at this size, there is hardly anything in it. Anyway, I have finally plucked up the courage to apply some paint, it doesn't look too bad, once it has been dirtied up a bit, no one will notice (I hope).
« Reply #124 on: June 19, 2014, 09:39:09 am »
 %)...mmmmmm you are making a really nice job on the chair arm Nick....... {-) .....
Why is the sea suction so low & in such a predominant  <*< place? ................. Derek
Pages: 1 2 3 4 [5] 6   Go Up
Page created in 0.189 seconds with 17 queries.
