Author Topic: Adam's Svitzer Maltby  (Read 6930 times)
adamD98
  • Born free, forced to work!
« on: March 27, 2013, 12:39:13 pm »
Hi Folks,
The time has finally come, I've got My Hull, Plans and Photo's (massive thanks to Tyne Models and Chipchase for all the help).
 Got a pair of Schottels (again with thanks to those who have given advice here) and a load of timber.
Ok, so what I need (advice welcomed as always):
- Bow thruster (what do you suggest?)
- Motors (Going with Graupner 900's) and couplings
- Working winch
- Plenty of Plasticard for the Superstructure!
And a lot of patience!!  O0 ;D {-)
 I've taken some photo's of the new hull and i'll start posting photo's as I go along the build.  :o :D  and so it begins!
Cheers,
-Adam-
Jerry C
Re: Adam's Svitzer Maltby
« Reply #1 on: March 27, 2013, 01:24:31 pm »
Adam, if you've got schottels and you know how to use them, you don't really need a bow thruster. Very few ASD tugs also have a thruster. The problems I foresee in an ASD model are that a real ASD unit can rotate 360° and although it is feasible to achieve this on a model, in order to be able to drive the tug you need some way of knowing which way they are pointing. Most descriptions of model "schottel" operation suggest a limit of 180° rotation. At first sight this is restrictive until you realise that it is possible to run the prop in reverse ( a feature which to my knowledge is only available astern to 30% power on true Schottels). On Aquamasters and Niigatas the prop only turns in one direction.  Having the ability to reverse the prop on a model ASD unit and rotation of the unit through 180° effectively gives 360° rotation. It would be very tricky to drive though but possible.
Jerry.
adamD98
« Reply #2 on: March 27, 2013, 02:41:33 pm »
Hi Jerry  :-)
 Thanks for that. I know that with Schottel's you have very good maneuverability, however the "real" tug has a Bow thruster, so I do want to try and replicate this, even if I do hardly ever use it.
 Don't get me wrong, I'm sure i'll more than likely hardly use it, even when towing but it's nice to think if I need it, it's there to use..if you get me?
 I'm just a little torn between using a "market" thruster or building my own.  %)
Cheers,
-Adam-
Jerry C
« Reply #3 on: March 27, 2013, 03:33:34 pm »
Ok mate, all understood. In that case I used a Graupner b/t in an Aziz. Worked well. Only difficulty was that it was 7.2volts and thus required a separate battery as rest of boat was 12volts. I used a 10A Mtronics marine ESC. Also good.
Jerry.
adamD98
« Reply #4 on: March 27, 2013, 03:38:38 pm »
Same as what I used in my Aziz (long since gone) - but I actually found it useful running the B/T from a seperate source. That's just personal preference though I guess  :D
Cheers,
-Adam-
« Reply #5 on: March 27, 2013, 03:50:28 pm »
Didn't' the real tug have controllable pitch props
not schottles which would account for the
bow thruster.
freshfrenchbread1964
« Reply #6 on: March 28, 2013, 08:54:56 am »
Hi Adam
pleased to hear all the parts have now arrived , will be watching with great interest. lets have lots of pictures of the build , hope to see her towing at balnemoor before the season end.
Cheers Nick
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
« Reply #7 on: April 04, 2013, 01:16:04 am »
bow thruster.
she is actually fitted with  2 x Rolls Royce Aquamasters variable pitch asd units !
[/size]
lets just hope this one floats !!
fire at will ! ... which one is will ?
andywright
« Reply #8 on: April 20, 2013, 09:06:04 pm »
 Any chance of a photo of the hull?
adamD98
« Reply #9 on: April 21, 2013, 02:10:16 pm »
Sorry folks - been having a nightmare few weeks!
 But, back on track just about so i'll get posting and cracking on!!
Andy, I took a few photo's of the Hull before I started it so i'll get them up for you over the next day or so.  :-))  It's an excellent hull, can't fault it at all personally.
Cheers,
-Adam-
ian-mccaffrey
« Reply #10 on: April 21, 2013, 07:46:43 pm »
 :-))  looking forward to it !  :D
T33cno
« Reply #11 on: May 06, 2017, 07:27:50 am »
What happened?
Butts
  • Secretary, Balne Moor Model Boat Club
    • http://balne-moor-model-boat-club.myfreesites.net/
« Reply #12 on: May 06, 2017, 08:41:07 am »
No doubt Adam will be back soon to answer for himself, but I guess the demands of a new baby son have slowed his building works somewhat :} .
T33cno
« Reply #13 on: May 06, 2017, 02:47:37 pm »
Good we'll possibly end up building at the same time  :-))  joint effort
