Author Topic: What is it?  (Read 6361 times)
yewgarth
What is it?
« on: March 30, 2013, 06:22:45 pm »
can anyone please tell me what this is? I've been doing model boats for over 40 years and have never come across one before. If any one does know could they tell me how and what it's wired to? Thanks, Martin
tica
    • Skalamodelskibe
Re: What is it?
« Reply #1 on: March 30, 2013, 06:58:20 pm »
I would say that it's a dual switch !
Does the IC state ZN409 ?
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
Rottweiler
Re: What is it?
« Reply #2 on: March 30, 2013, 06:59:45 pm »
showing what is written on the side might help someone identify it?
First opinion....its a thingy! (sorry couldnt resist that!)
Mick F
barriew
Re: What is it?
« Reply #3 on: March 30, 2013, 07:01:12 pm »
I agree with tica, whatever is on the IC :-))  Plug it into the receiver and you have two on/off switches controlled by one channel.
Barrie
Re: What is it?
« Reply #4 on: March 30, 2013, 07:04:23 pm »
Speed Control.
Klunk
Re: What is it?
« Reply #5 on: March 30, 2013, 07:11:14 pm »
That my friend is a dangle obtuse ojamaflip!
full time penguin
john44
Re: What is it?
« Reply #6 on: March 30, 2013, 07:17:08 pm »
Nope sorry klunk its the wrong color to be one of them.
john
yewgarth
Re: What is it?
« Reply #7 on: March 30, 2013, 07:59:15 pm »
definitely not a dangle obtuse ojamaflip a thingy or a speed controller! One of the boxes says.....
KG1P-F
RES. LOAD
10A 110VAC OR 24V DC
5A 220VAC
COIL DC 6V.
]Hope that helps.
Re: What is it?
« Reply #8 on: March 30, 2013, 08:02:38 pm »
The two boxes are relays.
  Regards  Ian
yewgarth
Re: What is it?
« Reply #9 on: March 30, 2013, 08:23:14 pm »
would it be a 6V output powered by the receiver?
tica
    • Skalamodelskibe
Re: What is it?
« Reply #10 on: March 30, 2013, 08:34:47 pm »
Flip it around and take a picture from the other side of the part and we will easily be able to tell you how to use this switch.
BTW: The 6V is the requride voltage to pull the relay on.
yewgarth
Re: What is it?
« Reply #11 on: March 30, 2013, 08:49:56 pm »
Like this.....
yewgarth
Re: What is it?
« Reply #12 on: March 30, 2013, 08:54:23 pm »
Or this.....
Sub driver
Re: What is it?
« Reply #13 on: March 30, 2013, 09:29:12 pm »
The chip zn409 was used in speed controllers like electronise before the chip went out of production and the speedos changed, there is also a variable pot for adjustment so might be as circlip says a low wattage speed control.
For what its worth regards sub.
yewgarth
Re: What is it?
« Reply #14 on: March 30, 2013, 10:01:50 pm »
Thanks Sub driver  :-)) . But i'll still welcome theories.
Snowwolflair
Re: What is it?
« Reply #15 on: March 30, 2013, 10:14:41 pm »
Dual relay switcher. One relay closes stick forward one closes stick back.
You could wire aux functions or a bow thruster.
yewgarth
Re: What is it?
« Reply #16 on: March 30, 2013, 10:26:06 pm »
and how exactly would this be wired snowwoflair?
nick_75au
    • Logan City Marine Modellers
Re: What is it?
« Reply #17 on: March 30, 2013, 10:26:40 pm »
Definitely a switcher there's no heavy components to variably switch motor current, useful for a single speed bow thruster or two heavy load (10 amp) items. You connect a + supply to the common terminal and your load + to the normally open contact for basic on off control of your load. The load neg is connected directly to supply neg.
For a thruster or reversible motor
the 30 terminal is common, 87 is NO and 87a is NC, tor the purpose of this exercise you can ignore the 85 and 86 terminal, they are taken care of by the board. (EDIT I Got NO and NC reversed :embarrassed: )
Nick
yewgarth
Re: What is it?
« Reply #18 on: March 30, 2013, 10:53:13 pm »
Brilliant, how good are you lot? Where else would you get this service?
More Coffee
Re: What is it?
« Reply #19 on: March 31, 2013, 03:04:29 am »
wrong thread.... %%
But I did notice a lack of fly back diodes..
The pot is probably to adjust the sensitivity.
The rest of the bits just help translate PWM into Voltage to crack the relays.
Re: What is it?
« Reply #20 on: March 31, 2013, 10:13:24 am »
Before three phase motors and ESCs, one step up from "Bobs Boards" was the speed controller that used a pulsed relay for speed control. The chip varied the on/off ratio of the relay(s) like a mechanical Triac.
   409 was one of the PWM chips fitted to many "Solid State" servos and replaced lots of discrete components
  Regards Ian
yewgarth
Re: What is it?
« Reply #21 on: March 31, 2013, 02:16:09 pm »
Errrrrr thanks........i think?
inertia
Re: What is it?
« Reply #22 on: March 31, 2013, 03:30:44 pm »
No question but that it's a dual relay switch. The legend on the copper side of the PCB actually identifies the Common, Normally Closed and Normally Open contacts of the Left and Right relays. I imagine the pot might control the switching point i.e. how far you have to push the stick before the relay is triggered. The only unanswered questions are
1. What is the current rating of the relays (often inscribed on the face of the relay itself)? and
2. Is the switch latching or non-latching i.e. does it stay closed when you let go of the stick? Easy enough to find out by trying it.
I'm curious to know who made it, as it looks like something which has been neatly DIY-etched onto plain copper-clad laminated paper board  rather than "professionally" produced on epoxy-cloth board. Could be from a magazine article. I think the ZN409CE chip went extinct around 1998, although I see they are still traded at around twenty eight quid EACH on Fleabay.......... I have a small supply which I am saving as part of my pension pot  8)
DM
grendel
Re: What is it?
« Reply #23 on: March 31, 2013, 04:49:56 pm »
it said 10A at 24V DC (relays will have a different rating for dc and AC)
Grendel
inertia
Re: What is it?
« Reply #24 on: March 31, 2013, 05:17:41 pm »
O, yeah - missed that bit!
Mind you, I've just spent half an hour looking for 100 x LEDs which I was convinced I'd thrown away by mistake, only to find them sitting in a drawer of a storage cabinet which I'd labelled up and where I'd put them only on Thursday............... What???  :o
Why is it I can remember stuff from 40 years ago and yet I forget things I did this week?
DM (pronounced "dumb")
