Author Topic: THE NEW ENGINE BY MARTIN BAYLIS  (Read 16037 times)
MOG8
« on: April 22, 2013, 03:58:43 pm »
I am pleased to share with you the first few images of the new Steam Engine "ENGLAND" a three-cylinder engine designed by Martin Baylis, designed from a rib of the  twin cylinder "England".
3-cylinder Bore x Stroke: mm. 9 x 12, with a displacement of 4.58 cc.
Change of direction RC, by Maudslay reversing gear.
RC throttle control.
This engine  is not yet officially on sale, and the tests which are carried on are very encouraging,.
It is very light, very powerful, and very fast: it can reach 3,000 rpm without problems at 3 bar.
It is technically very advanced:
Crankshaft, eccentrics and  big ends are supported by needle bearings.
Cylinder block, valve box and motor base are made of hard anodized aluminum.
Smooth  piston without o-rings. The sealing between the piston and cylinder occurs when the motor is thermally ready to run through the expansion of the cylinder block. In this phase of preheating, the condensed steam can thus escape through the exhaust pipe.
Its very detailed and refined aesthetics have nothing to do with the English sand castings to which we are very familiar or with the squarish shapes of the new CNC engines.
You will find the outlines of the engine here:
http://www.model-steam-engines.co.uk/page5.html
The price?
Keep dreaming!
Exhaust End by STEAMPROPULSION, on Flickr
Cladding Oblique by STEAMPROPULSION, on Flickr
Cladding side by STEAMPROPULSION, on Flickr
Exhaust Oblique by STEAMPROPULSION, on Flickr
From above by STEAMPROPULSION, on Flickr
ê
Inlet End by STEAMPROPULSION, on Flickr
Steam Chest Oblique by STEAMPROPULSION, on Flickr
Steam chest side by STEAMPROPULSION, on Flickr
Giovanni
Mickeyfinns
Re: THE NEW ENGINE BY MARTIN BAYLIS
« Reply #1 on: April 22, 2013, 05:31:26 pm »
What a well engineered piece.  :-)) :-)) Love to see it running. 8) 8) 8)
SPERO MELIOR
(I hope for better things)
eddiesolo
« Reply #2 on: April 22, 2013, 05:50:17 pm »
Looks lovely, know naff all about steam but always love the engineering of small engines. Bet she has a price tag to go with the splendor.
Si:)
ooyah/2
« Reply #3 on: April 22, 2013, 07:52:50 pm »
Si:)
Eddie,
Bank loans spring to mind !!!!!
George.
frazer heslop
« Reply #4 on: April 22, 2013, 08:25:40 pm »
Shame Iv spent my pocket money
I wish
eddiesolo
« Reply #5 on: April 22, 2013, 08:30:19 pm »
I know that they're amazing pieces of miniture engineering but, are they really that expensive? What are we talking about? £100, £200, £300...more.
Si:)
ooyah/2
« Reply #6 on: April 22, 2013, 08:36:16 pm »
Si:)
Eddie ,
You wish !!!
Not much change from 1k maybe 2k
George.
eddiesolo
« Reply #7 on: April 22, 2013, 09:07:03 pm »
WHAT?! I'll stick to electric boats then. So, you need engine, boiler, pipework etc...so you have just spent a small fortune before you even think about the boat you're putting it into. A real passion to spend that sort of money.
Si:)
« Reply #8 on: April 22, 2013, 09:15:33 pm »
Steam ain't cheap if you are buying it in.
eddiesolo
« Reply #9 on: April 22, 2013, 09:19:45 pm »
Sounds like it Colin, beautiful to see and hear but, sadly way beyond my cash flow.
Si:)
« Reply #10 on: April 22, 2013, 09:46:24 pm »
Si:)
It doesn't have to be... take a look at mad mikes inspirational thread
http://www.modelboatmayhem.co.uk/forum/index.php/topic,39774.0.html
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #11 on: April 22, 2013, 10:43:31 pm »
Beautiful engine, one thing I can't help but wonder- why the centre height of the crankshaft is so high? There is no room at all for mounting the engine straight onto engine beds, or on a common tray with the boiler, as the engine would have to be mounted at quite steep angle to make alignment with the propshaft viable.
The cylinder casting is a work of art, looks absolutely perfect!
Greg
« Reply #12 on: April 23, 2013, 07:15:54 am »
Don't need to worry about blow holes and inclusions when the big (and small) bits are cleaved from "Billet". As George mentioned on one of their previous efforts, Displacement lubricator can't be very effective. Strange choice of material despite tough skin.
  Regards Ian.
ooyah/2
« Reply #13 on: April 23, 2013, 09:47:57 am »
Ian,
 It's the old adage " if it looks too good to be true it probably ain't " apart from the peculiar position of the lubricator it's never a good thing to make engines without a crosshead on the Con-rods even though the piston rods have long guides and to have needle bearings on the main shaft it will have to be a shaft that's pinned together with grub screws which can create long term problems.
 Not sure whether it's supposed to be a triple expansion engine or is just a pretend one with the different size cylinder covers and the Maudsley reverse gear isn't a new thing, Cheddar used it on one of their engines.
 It never ceases to amaze me that engine makers advertise engines that will do 3,000 rpm on 3 bar, yes it will do that , on the bench , but not in the water driving a boat and who in their right mind would want 3000 rpm in say a big tug, it will take a big boiler with a big fire to maintain those sort of revs.
Apart from these observations it's a well made engine but I fear that it will be way out of reach of most modelers price wise unless being CNC machined they can churn out hundreds of parts to keep the cost down.
George.
« Reply #14 on: April 23, 2013, 10:07:23 am »
Evening George..........I am a little lost with the following...
" it's never a good thing to make engines without a crosshead on the Con-rods and to have needle bearings on the main shaft it will have to be a shaft that's pinned together with grub screws which can create long term problems"
I am unsure of the issue in the relationship between pinning a crank with HPGS & having assumed  Torrington style sealed needle roller bearings......& assume these to be stainless steel caged & ZZ fully sealed
We can all learn from experience :-)) .........regards Derek
MOG8
« Reply #15 on: April 23, 2013, 05:58:46 pm »
Greg
The centre-line of the crankshaft of this engine is 14 mm high from the base. That if the TVRIA is 12 mm.
Giovanni
ooyah/2
« Reply #16 on: April 23, 2013, 08:57:08 pm »
Hi Derek,
Lets see if I can enlighten you to re-find your way.
If you look at any of the Stuart engines and the one made in OZ you will notice that the con-rods are connected to a cross head that slides up and down in the cross head guide, this takes out the strain of the angular thrust on the piston rod as the piston drives up and down and greatly reduces piston and piston rod wear.
To have needle bearings on the main shaft it must be able to split to get the bearings on and then pinned with HPGS  and thro' time can loosen and cause all sorts of misalignment problems.
It's my opinion and preference to fabricate the crankshafts , glue with industrial glue ( Loctite 603 ) leave to cure for 24 hrs and then drill and ream the webs for 3/32"  taper pins, cut out the piece of the main shaft not required and file and finish, this is my preference as against Silver Soldering the webs to the shaft.
This gives a very strong crank shaft with solid Gunmetal outside bearings and 1- split bearing in the middle but it's only my preference and opinion as I prefer to stick to full size practice and don't see the need for needle bearings on our size of toy engines.
I hope this helps but remember, it's only my opinion and everybody is entitled to theirs and if they have the cash to purchase one , go for it..
George.
gondolier88
    • Coniston Regatta
« Reply #17 on: April 23, 2013, 10:09:35 pm »
Ian,
George,
I'm interested to see how these engines hold up without cross head guides- but I can see where the idea has come from, looking at the technology and research that has gone into hydraulic rams, with a super accurate piston fit, honed cylinder liner, long gland/guide length and a proper sleeve packing, rather than wraps of gland packing material. Also, check out the diameter of the piston rods- they seem to be at least 30% bigger than you would normally expect.
A lot of experimenting though, when re-inventing the wheel has been done so many times before.
Greg
« Reply #18 on: April 23, 2013, 10:49:56 pm »
George....thanks I now understand where you are coming from the construction aspect
I can only assume that the engine manufactures using miniature ball or needle rollers & HPGS are also using a LOCTITE super weld medium
[Anton & JMC [in certain engines]  have been using ball bearings for approx. 8 years, and recently the BB version of the TVR1A and now the Baylis engine] ...[Saito have also used the fabricated big end & HPGS for 20 years]
Greg...working exclusively with hydraulic cylinders/actuators we have seen over the past two decades greater use if composite materials, lower diametrical clearances and higher pressures
Equating a chemically hardened aluminium material to equal sapphire  on the Mohs scale is fine & the way I read the text is that the cylinder head is of aluminium construction, but I do not see a nomination of the piston material, nor any concern of differential expansion due to temperature increase between the dissimilar metals.........................
Cleanliness & lubricity is also paramount with the first slug of steamy water to pass through our engines......
Are the piston rod glands adjustable [for seal wear]? or is it just a mockup?............Derek
pettyofficernick
« Reply #19 on: April 23, 2013, 10:56:00 pm »
I would imagine these engines will be grossly overpriced, as is all MHB kit. Looking at their twin cylinder engine, it is exactly the same, it looks like they have just extended the bed and made a bigger cylinder block, most of the other parts will be common to both engines, spewed out by a CNC machine, probably under subcontract to an outside firm. I do not like the un supported crossheads, they don't look the part at all, and imagine if the engine had to do any proper work for any length of time the glands would soon be worn and leaking steam. far better to have a trunk guide as in TVR's or Stuart Double tens, or 'slipper' type guides as in Stuart launch engine. I think Stephenson's valve gear looks much better than the Maudsly gear, which is, at the end of the day, basically a camshaft with eccentrics instead of cams. If they are configured as a triple expansion engine, a simpling valve arrangement would be needed to get the engine running as TE's are difficult to self start. Well, thats my twopenneth  there are probably those who disagree, but to each his own, They are, as far as I am concerned, the 'bling' of the model steam world.
« Reply #20 on: April 23, 2013, 11:01:38 pm »
That sounds like a lot of unsubstantiated assumptions Nick. If you are going to criticise then you should establish the facts first not just 'imagine'. You seem to have a bit of a downer on the manufacturer.
pettyofficernick
« Reply #21 on: April 23, 2013, 11:16:23 pm »
I'm not assuming anything, it would be next to impossible to manufacture these engines without CNC machining, that is not an assumption. The angular forces acting on the piston rods are bound to cause wear with any proper use, by proper use  I mean regular and prolonged running, I sail my steamers 6 to 8 hours a week throughout the year, weather permitting, and quite often, when the weather does not permit. As I said, that was my opinion, no doubt others will form theirs. Yes, they will look very nice in a museum quality boat, but for the price they are likely to attract, not a proposition for going to the lake 3 mornings a week. I do not have a downer on MHB, I just think their products are way too expensive......
gondolier88
    • Coniston Regatta
« Reply #22 on: April 23, 2013, 11:24:39 pm »
Sorry for the lack of proper quote, the button didn't want to work for some reason!
Firstly, MHB is not overpriced, it is what kit of this quality costs to make and make a profit on top, other manufacturers make lots of models of a good quality and make their margins, just. MHB make a few high-end pieces, that will never lose value, and if looked after are investments in themselves.
If they have extended the bed of the twin and and added a third cylinder they are copying marine steam engine construction methods from the last 150 years, and I'm not really entirely sure what your problem with them doing so is?
I agree, cross-heads do look 'right', and perform their job admirably if made properly, but have can you substantiate your claims with proof that the glands designs and materials they have chosen won't stand the test of time? There are millions of hydraulic applications out there that use the piston and gland as guides only that don't leak a drop at much much higher pressures than our engines work at.
Stephenson's gear is unsophisticated, noisy, inefficient as it wears and requires the friction of four eccentrics to drive it (edit- in a TE, of course, there would be 6 eccentrics), plus loss of energy through the natural errors in the arcs of the die-block. Due to these errors the majority of Stephenson's geared engines have glands that pass water, even in small amounts, this water goes onto the valve gear and fights any lubrication, adding to wear issues. Gear driven valve gears have none of the above, and will give hundreds, if not thousands, of hours of reliable steaming with nothing more than a bit of oil on the gears. On the other hand, through a little thought, MB could have got around the problem of water ingress into the eccentrics from the valve rod glands, but have chosen not to.
Lets see if anyone on this forum gets one and sticks it in a boat.
Where's Kusuchi when you need him....
Greg
Colour changed, as Blue  is reserved for the moderating team
Ken
« Reply #23 on: April 24, 2013, 03:51:48 am »
Here is a translation from Giovanni from a French WEB site....same text...just one or two words translated differently .....
From the original posting here, I had quite some difficulty in understanding how the engine would function without any form of piston sealing element.......Derek
English WEB text
French WEB text
Smooth and seamless piston o-rings. The seal between the piston and cylinder happens when the engine is thermally ready for use thanks to the expansion of the block cylinders. In this phase of preheating the condensed steam may escape through the exhaust tube.
« Reply #24 on: April 24, 2013, 10:04:41 am »
   Difficult being a compound if all three bores are the same. Would suggest that MBH have "rollerised" the shafts to offer the normal bling market an alternative to the TVR. Do you really need needles at 3K RPM?  Sealing between pistons and bores if as quoted aren't going to do much for the compressed air fraternity.
Page created in 0.157 seconds with 18 queries.
