some times my lap top will judder :: on some pages up and down before it settles down what is the solution
Getting back to the subject without getting sidetracked turning the mouse over to check for nipples and balls, a good start might be to clean the operating system. I usually start by downloading and running a copy of malwarebytes then the same with a copy of ultradefrag or auslogics defrag and auslogics registry cleaner then give it a go with startup inspector for windows.
Between them they usually get rid of anything that has no business being there, clean up any space left, tidy the registry and the last shows what programs start up on switch on. Remarkably few are needed, most (like printer programs) just take up resources. No idea what is causing the problem because I haven't had it, but doing the regular cleanout usually gives useful clues somewhere along the way if it doesn't accidentally do a cure.
Not using a mouse implies using the trackpad. On my presario CQ56 (got because it was cheap in ASDA) I used the control panel to attack my trackpad (=mouse) settings to get rid of all the fanciful stuff to avoid confusing myself. Because I hate using the trackpad, I invested about £3.50 in a USB mouse. Life is much simpler with the rodent.
