Author Topic: A bit of help please  (Read 3122 times)
markit
« on: May 04, 2013, 08:15:59 pm »
Need a bit of advice (well actuall a lot) please, now ready to get my radio control gear, problem is i have no idea what i need. It is to go in my HMS Sheffield i am building can someone please advise what would be a good make and what i would need. About the only thing i know is i need a 2 channel set up, rudder and motor. I know someone will be able to advise.
Many thanks in anticipation
Re: A bit of help please
« Reply #1 on: May 05, 2013, 11:12:13 am »
If going for an AM or FM outfit, 2 channels is the cheapest option, but if going for a 2.4GHz 4 or 5 channel set, there is almost no price difference.  Just use the channels you want.  You might think of a use for the others later.
There is the advantage of not having to bother about having crystals that don't clash with anybody else.  The downside is that there isn't much compatibility between makes, so any future receivers would have to be the same make and possibly model to bind with the transmitter.
Good makes?  At the basic level, anything listed by the major UK hobby shops will be OK.
triumphjon
« Reply #2 on: May 05, 2013, 11:49:19 am »
i personally wouldnt buy anything in the am/ fm range unless you plan to have a submarine , for the current price difference between the am/fm 2 chanel sets and the 2.4ghz multi chanel radios  id buy a 2.4ghz set up ,  no interference to worry about .
« Reply #3 on: May 05, 2013, 03:20:37 pm »
 I agree Jon
If you are not running Submarines there is no reason to buy anything than 2.4Ghz
gear when starting out in the hobby.
No frequency clashes and no antisocial aerials waving around at the lakeside.
markit
« Reply #4 on: May 07, 2013, 01:30:06 pm »
Ok so a  2.4 GHz system it is then
anyone recomend a good make and what sort of price range am i looking at
once again many thanks
richald
  • Retired and loving it!
« Reply #5 on: May 07, 2013, 02:15:51 pm »
Radiolink gear : cheap and cheerful, I have two transmitters and six or seven receivers and they
seem reliable enough.
transmitter and receiver : £27.18
http://www.giantshark.co.uk/giantcod-24ghz-4channel-mode2-transmitter-p-403779.html
receivers : £10.24
http://www.giantshark.co.uk/radiolink-receiver-r7eh-p-405468.html
you can bind several receivers to one transmitter - this allows you to use one transmitter with several boats
I shall leave it to others to recommend other (more expensive) radio sets, Planet T5, Hitec, Futaba etc.
Richard
I notice you are Sheffield based - where do you sail ? - I used Millhouses Pond when I lived in
Sheffield - nice pond, easy parking and great cafe
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
« Reply #6 on: May 07, 2013, 02:17:16 pm »
It all depends on the depth of your pockets.... The flysky systems have a very good reputation and can be had for about 40 pounds including the receiver.
http://www.giantshark.co.uk/flysky-6channel-transmitterreceiver-p-406150.html
or there is the Plant system
http://shop.huntersystems.co.uk/planet-t5---24ghz-digital-remote-control-system-1473-p.asp
both are good budget systems
When you consider a 2Ch 27 or 40Mhz system will cost you about the same, like others have said it seems pointless
Another good system is the Spektrum DX6i and DSM system but this is almost double the price, but then there is the Orange range of receivers that can be picked up for about a fiver each which makes this a contender.
Also Orange now do there own TX which is getting good reveiws.  A good TX if you can get over the styling as its not to everyones taste
http://www.hobbyking.com/hobbyking/store/__28494__OrangeRx_T_SIX_2_4GHz_DSM2_6CH_Programmable_Transmitter_w_10_Model_Memory_Mode_2_.html
The there are the more expensive brands like Futaba and JR
markit
« Reply #7 on: May 07, 2013, 08:34:01 pm »
thanks for that info will look in to the options
Hi Ricald i dont sail as yet am just building my first ship at the moment. The sheffield modelboat club still use millhouses pond  dont know where i will be sailing yet still at the construction stage at the moment
Guy Bagley
« Reply #8 on: May 07, 2013, 09:20:59 pm »
etronix do a 2 channel 2.4 ghz set, - type it into ebay or google, you will find them for about £35 TX /RX combo brand new.....
so good i have 4 of these sets now for my sons buggies and boats
