Author Topic: New Project - Snow Goose - Classic Broads Cruiser  (Read 3074 times)
Roker
« on: May 10, 2013, 08:56:34 am »
Just purchased the kit ‘Snow Goose’ from Deans Marine, looking forward to the build, has anybody built this?
 Any feed back information / pictures would be great. ;D
Roker
Re: New Project - Snow Goose - Classic Broads Cruiser
« Reply #1 on: May 13, 2013, 03:01:20 pm »
Kit arrived today, After a quick rumage in the packed box it looks like a comprehesive piece of kit includes all fittings with Glass fibre hull & decks. Vacformed fore cabin. motor mount etc.
Will keep you posted with pictures of build progress.... %%
« Last Edit: May 13, 2013, 03:04:48 pm by Roker »
Roker
« Reply #2 on: May 15, 2013, 04:13:36 pm »
The box.
Simple Plans in colour.
Fittings in tray.
Fibre glass hull & Vac formed parts
Stand built from simple templates in the instructions
More to come.....
« Last Edit: May 15, 2013, 04:22:07 pm by Roker »
eddiesolo
« Reply #3 on: May 15, 2013, 09:08:31 pm »
Looks a nice kit. Is the quality good?
Si:)
Mad_Mike
  • Lincolnshire
« Reply #4 on: May 15, 2013, 09:50:33 pm »
I just read your thread on the gentlemans runabout. I cant beleive i missed it, brilliant it was. Ill stick around for this one and keep an eye out for any of your posts in the future.  :-))
Roker
« Reply #5 on: May 20, 2013, 07:46:57 pm »
First job sanding away excess glassfibre on top edge.
Mini Belt Sander photo SG-11a_zpsa06f829f.jpg"
This mini belt sander came in handy.
Drilling holes for Rudder & Prop shaft support.
Positions identified by two raised 'spots' on moulded hull.
Pictures on the instruction are a bit confusing (picture shows rudder fitting aprox. 20mm from back edge of hull - THIS IS WRONG)
After talking to deans marine the instructions are based on the first protype builds, so are a bit out of date.
So look out for updates on this build.
Next the Rudder tube exit, again marked on hull.
WHITE METAL FITTINGS  {:-{  for those who are familiar with this material the castings can be a bit rough so a lot of time can be spent hand filling fiddly little bits supplied in the kit, so patience and care is required.
Example the prop shaft support. Not a great casting but still usable after filling to shape to fit prop shaft tube. Removing the loction lug and replace with brass pin / wire for extra strength.
Vacformed parts are part of the kit, including the Motor Mounting.
So next trial fitting motor, prop shaft & rudder fittings....keep looking.
« Reply #6 on: May 20, 2013, 09:02:41 pm »
I'll tag along with your build - spent some good holidays on the Broads  O0
ardarossan
Re: New Project - Snow Goose - Image glitch query?
« Reply #7 on: May 20, 2013, 09:26:07 pm »
Are the images supposed to be clickable, as I'm getting an error code everytime I try to expand (any of) them?
Roker
« Reply #8 on: July 01, 2013, 05:24:44 pm »
Been a while, more pics of the build:
Servo Assy photo DSCF3145_zpscf2c8355.jpg"
OK that's the basic hull build more or less nearly done.... But a lot more to do...  (Found some problems with instruction / build) keep watching to find out?
