So let us continue.
So I started building a cabinet on rolls for the table circular saw. As even using the means to absorb dust and chips, a lot of those generated when working with the machine I opened a hole on the surface of this cabinet with the same geometry as the opening of the saw on its bottom.
This view from the bottom of the saw shows the grid plate which I have to remove.
Here you see the bottom of the saw with the grid plate removed. Here also, but I will do this later, you see on the left side of the opening where I will install the device that will be able to show me on its display the height of the saw blade above the surface of the table.
Here you can see the extension of the lateral stop of my circular table saw.
The wooden plate on the left of the lateral stop is to prevent that the screws that fix the extension bend the lateral stop. Between the lateral stop and the wooden plate on the right is the tube that I will connect with my dust and chip absorption system. This same wooden plate is where using a groove on it to fix the aluminum plate that has grooves on both sides with those special screws that use those grooves.
On this front view of the lateral stop extension for the router table, you can see that there are 2 aluminum plates with grooves. Those 2 aluminum plates can be moved to adapt the opening to the dust and chips absorbing tube so that its width can be adapted to the milling cutter in use. You also see the blue-colored aluminum plate from which the router is hanging. The metal sheet you see is available of two different sizes to be used to have the opening to the milling cutter as small as possible. To the right of it, one of the holes in the aluminum plate is to insert the crank handle that enables me to change the height of the milling cutter above the table surface. The transparent plastic device mounted in one of the grooves of the aluminum plates is there to protect my fingers from slipping accidentally on the milling cutter and which position is adapted to the height of the workpiece being worked on. As I wrote earlier, the 2 columns are the ones that prevent the desk from being bend by the weight of the router. What today is already done is aligning the surface of all the elements on the router table to be at the same level.
Here a view of the router hanging from the blue-colored aluminum plate.
The green elements you see mounted one on a groove on the surface of the table, one wrongly mounted on the left aluminum plate. It is BOW Feather DUO which I did purchase from a company called Dictum herein Germany. I also offer the possibility to mount both feathers one on top of the other separated to press a high workpiece. The feathers are to press the workpiece against the table surface and against the lateral stop. These are important tools to protect the operated from being hurt. Workpieces can fly and hit the operator and they can be drawn into the opening next to the milling cutter. Also against this, the feathers have to eliminate risks from the operator. I will possibly buy a second set of these feathers.
The next 2 images of devices I did purchase that adds to my safety when operating both the circular table saw and the router table.
I may be too careful buying all this stuff for my machines, but my wife and my kids demanded me to do whatever was possible not to get hurt.
I also did purchase a lot of 3D printed parts to help to align the elements of the desk on the side of the circular saw blade as I have already done on the side of the router table. A good friend of mine also 3D printed parts for the dust and chip absorbing system in my workshop. So I decided that 3D printers are really useful to support in working on advancing my workshop and for 3D printing parts for my sailboat model project.
I did choose the Creality Ender 5 Plus printer because of 2 reasons: One is the cubic form of its frame. That promises pretty good stability. Remember a 3D printer can print layers as thin as 0.1 mm. So the smallest amount of vibration will impact and get visible on the printed object. The other aspect is that it offers the largest printing values between consumer 3D printers. Studying topics around 3D printers I learned that 3D printers undergoing revolutionary technology development, upgrading parts of it become a mainstream issue. But I also did learn that the devices to drive the stepper motors are from the company Trinamic, whose boards I did extensive experimenting to learn as much as possible about stepper motors as I do plan to use stepper motors as winches. 3D printers use a standard called "SilentStepSticks" for which there are sockets on the controller board. I did purchase the BTT-SKR-PRO V1.2 controller board that has 6 sockets for this driver board. They are also used to drive the heater for the platform on which a 3D printer builds the objects and the extruder. An extruder is the element of a 3D printer to heat the filament that is fed to a nozzle which then applies the material.
Having that experience with stepper motors and with Trinamic stepper motor drivers, I did purchase SilentStepSticksTMC5161 that is the most powerful stepper motor driver used in those SilentStepSticks and I did purchase a Meanwell 600 W 48 VDC power supply to be able to have the stepper motors to be driven at highest possible speed so that the 3D printing process can takes days to print a single object. You cannot imagine how I was exposed to personal attacks and offends by planning to do so. I also found out that the NEMA17 stepper motors used in 3D printers have no plate to indicate their brand and its nominal values for current and voltage. I found out further investigating to learn that the stepper motors used in 3D printers are about the weakest and therefore cheapest NEMA17 stepper motors. So later I will replace the stepper motors on my 3D printer with ones that are 3x as long and have about 3x the torque. Those attacks are due to a total lag of in-depth knowledge about stepper motors and about the controllers used in 3D printers. They are just there to know that there are 8-bit and 32-bit controllers and that the latter contains more memory making it possible to add more code to adapt the os called Merlin to upgrades. While their "standard" controllers, again a surprise to me, are the LPC1769, an ARM 3 controller from NXP operating at 120 MHz. The one board, which I did purchase has an ARM 4 controller operating at 168 MHz. In tests done at the YouTube channel called "Kersey Fabrications", it showed that even switching to a more control power demanding color bitmap graphics can have the consequence to be responsible for stepper motor step errors and resulting in printed objects with quality problems. With my experience with ARM controllers from NXP, I would have chosen an ARM4 device with 2 cores. One being an ARM3 and one being an ARM0+. The first to process the language of 3D printers and CNC machines G Code and the ARM0+ to process I/O and the display i.e.! Even more, those controllers cost very little more than single-core controllers but operate with frequencies of up to 220 MHz.
But one error I had I could identify analyzing the attacks where they contained real information. It is only the amount of current flowing through the coils of a stepper motor. But the higher voltage, i.e. 48 VDC compared to the up to 24 VDC you find in 3D printers is that the induced voltage that has inverse polarity compared with the voltage applied did make possible much higher stepping frequencies as the resulting voltage from adding those 2 voltage values takes much higher frequencies to affect the torque available from the stepper motor.
