Model Boat Mayhem - Forum
Author Topic: 1 Amp Charge Rate  (Read 794 times)
Terry
1 Amp Charge Rate
« on: May 28, 2013, 06:48:53 PM »
7.2 volt NiMh 5000 mAh Racing Pack, is it OK to charge at 1amp
Thanks, Terry.
Re: 1 Amp Charge Rate
« Reply #1 on: May 28, 2013, 06:49:31 PM »
yep will take roughly 5 hours tho
Steve J
« Reply #2 on: May 28, 2013, 07:45:26 PM »
I would charge at <= 0.5A (0.1C) using a dumb charger and 4.5-5A (0.9-1C) using a peak detecting charger. I would only charge at 1A if I was sure that the cells were flat and was using a charger that can be programmed to terminate after a given time or amount of current.
Steve
