Author Topic: 5 hour diorama challange.  (Read 3334 times)
eddiesolo
« on: June 03, 2013, 12:16:43 am »
Righto, went sailing with club this morning and all was well until I got a burnt out ESC, never mind. Once back home my mate phoned me and suggested a 5 hour diorama challenge!
RULES: 5 hour deadline. Model had to be scratch built from junk and only one small piece of proper model item used if need be, had to be painted and mounted.
So, I set out scouring the junk bin and decided to do what I do best...yep, you guessed it, a sunken WWII mini sub.
The proper piece of model kit I used was a small brass propeller and that was all.
So, what did I use and how did I build it?
I had some used inhalers so I used the caps to make the two hull parts, stripped the insides to make the small conning tower and periscopes and other internals to give a section of inside hull bracing and access way. A small piece of old plastic tubing was added for effect.
To fasten together the whole structure, inside and out, was welded by using my soldering iron, quicker than glue and far stronger. Once complete it was onto the grinding wheels for some destructive and decayed work, then it was my sand coat, then sealed in spray paint, left as long as I dare in the sun and then mounted to a rather nice plinth, seabed added and then sponged. The rudder and planes supports are just copper wire bent into place-rudder and planes lost.
Bottom picture shows inhaler as it should be, then the two caps hot welded together with the internal part of the inhaler attached to the top-this was a test piece and not actually used as the weld was crud so re-did it using two more and then added internal structure, not really visible on the pictures.
Total build time: 4 hours and 47mins.
My mate made a plane but dropped it and it fell apart...silly boy  %%
Some piccies of the winner!
Si:)
vnkiwi
Re: 5 hour diorama challange.
« Reply #1 on: June 03, 2013, 01:53:11 am »
Very neat.
Very nicely done, using whatever's at hand, a man after my own heart
cheers
vnkiwi   :-))
« Reply #2 on: June 03, 2013, 08:16:09 am »
5 Hours!?!?!?! that would take me 5 months and still wouldn't look half as good.
eddiesolo
« Reply #3 on: June 03, 2013, 10:36:42 am »
Very neat.
cheers
vnkiwi   :-))
Why thank you, surprising what 'junk' can be made into.  ;)
Si:)
eddiesolo
« Reply #4 on: June 03, 2013, 10:39:00 am »
Very nice of you to say so, it isn't too hard to do really as a sunken wreck is far easier to do than a nicely painted and made model. If that was the case in 5 hours I would have only got the hull and deck glued  :D
Si:)
eddiesolo
« Reply #5 on: June 03, 2013, 11:54:44 am »
Some natural light piccies.
Si:)
Mad_Mike
  • Lincolnshire
« Reply #6 on: June 03, 2013, 10:29:38 pm »
burnt out esc?
Youve really got the hang of this clapped out old boat thing, you dont even have to try anymore they do vandalise themselves! :}
On serious note though well done on the diorama, sorry to hear about the esc. What was it water ingress?
eddiesolo
« Reply #7 on: June 03, 2013, 10:33:10 pm »
Hi Mike, don't know, there was water in the boat, from swells and splashing but nothing severe. The ESC is above the waterline on a platform, buty you never know. Nothing fouled on the prop the wiring was cool as was the motor-motor running free so no idea, just lost power then smoke pouring out of the wheelhouse, the back of the ESC waterproof coating was pushed out and blistered like something had just gone pop inside.
Si:)
« Reply #8 on: June 03, 2013, 10:51:34 pm »
ok what make was the ESC
eddiesolo
« Reply #9 on: June 04, 2013, 07:37:49 am »
It was a Perkins Dave.
Si:)
