Hi David, I find that once I have started a model I have to see it through to completion. I spend around 2 to 4 hours a day, depending on what stage I am at. A plan...plan you say...pfttttt...don't talk daft...just go with the flow man
Actually I do some research on the models prior to the build, in this case more details came to light after I had built her...most was small details like seaplane catapult still in situ, a mast against rear turret, turned out to be a crane and the compression damaged hull, that has been fun...not
to try and do. So, lesson for this build is to do your homework prior to building...problem is...I get too excited and want to build it NOW!
Thanks for commenting and pleased you like my work.
Si:)
