Author Topic: Hull plating  (Read 2154 times)
Chieftain
Hull plating
« on: July 06, 2013, 01:59:34 am »
I am well into construction of a Clyde Puffer scratch build from plans, and have been mulling over my choices for scale looking hull plating.
The vessel "Cloughlight" is a 1890 era coal fired, steam powered, iron hulled puffer.  The plans were drawn for building a cardboard display model or a wood R/C model.  I scaled up the original plans by 200% which gave me a hull that is just under 4 feet long.
The plans include a very good set of templates for cutting out strips of material to glue onto the hull that are indented to simulate the plating.  My first thought was to use 1/16" plywood and fit the strips.  The problem is that the plates on a puffer overlap, and I am not sure of the best way to go about doing that, especially on a hull I intend to put in the water.
I built the hull using 1/4" plywood for the frames and 3/8" ply for the keel.  I used styrofoam blocks between each frame to provide even spacing and keep everything parallel.  The foam adds a great deal of strength and will provide an excellent support for the plating.  I intend to glass the hull with epoxy resin and a light glass cloth, then sand it to break the gloss, and prepare it for plating.
Looking for any suggestions from anyone who has done a plating project before, and any tricks, tips, or pitfalls you can share.  I will put up a build thread for this boat a bit later...
Thanks!
BarryM
Re: Hull plating
« Reply #1 on: July 06, 2013, 08:11:47 am »
It's all there if you look. Go to 'Masterclasses' and read Bryan Young's thread on 'General Havelock' which includes the application of rivetted plating.
Barry M
boat captain
Re: Hull plating
« Reply #2 on: July 06, 2013, 12:31:26 pm »
I used brown gummed tape cut to size of plate then the riveting was embossed on to the tape using a dressmakers wheel also known as a pounce wheel.  The tape was glued on with pva and when completed coated with several coats of matt exterior varnish.
Joe
Joe
Liverpool MBC Committee Member
Chairman the Model Boat Convention
Chairman Merseyside Model Boat Association
Chieftain
Re: Hull plating
« Reply #3 on: July 06, 2013, 04:13:13 pm »
Thanks for that steer, that's a great build thread that is right up my alley.  Bryan's explanation about why indented rivets look good to the eye makes a great deal of sense and sure simplifies my project's goals.  Thanks, and I will work on getting a build thread of my own going.....
