Author Topic: 2.4ghz Please help  (Read 3741 times)
jason1111
2.4ghz Please help
« on: July 22, 2013, 11:54:03 am »
hi  I am new to this so I am in need of some help
I have a bait boat that I want to convert to 2.4ghz I have purchased a Saturn x4 tx and 6 ch rx
the problem I am having is I want to control the boat left  right reverse and forward by using one transmitter knob
my boat has 2 marine 15a msronic4 speed controlers and is fitted with 2 motors
any help would be much appreciated
john44
Re: 2.4ghz Please help
« Reply #1 on: July 22, 2013, 12:20:05 pm »
Hi Jason,You can do that quite easily by using up and down stick for
forwards & reverse and left & right on the same stick for
 a mixer, to control the motors for turning the boat.
you just have to decide which stick as usually only1 is spring return.
john
jason1111
« Reply #2 on: July 22, 2013, 12:34:30 pm »
yes but the motors seem to be working individual when I connect the 2 speed controlers to the rx
if I push forward on left stick one motor will work and if I push forward on the right stick the other motor will work
if you get what I mean , like  I say I am new to this so I apologise if this sounds a bit novice to the more experienced
« Reply #3 on: July 22, 2013, 12:55:12 pm »
This is 'Tank Steering' Jason.
You can steer the boat by speeding up one motor and slowing down the other.
Does the boat have a rudder or rudders?
If you have a rudder on the left/right of the stick  then you will need a Y lead to
enable you to connect both esc's to the channel for the up/down on the same stick.
If you are not using a separate receiver battery, you will need to disconnect one of the
receiver plug red leads.
jason1111
« Reply #4 on: July 22, 2013, 12:55:38 pm »
oh right just been on goole and I see what you mean I have to buy a mixer
will a V-Tail Mixer do the job
jason1111
« Reply #5 on: July 22, 2013, 12:58:44 pm »
hi ned
 the boat has two motors that are prop driven
« Reply #6 on: July 22, 2013, 01:25:34 pm »
Does the boat have a rudder or is it designed to use the motors for steering?
inertia
« Reply #7 on: July 22, 2013, 01:57:27 pm »
The article "Do they both go round, mister?" will explain mixers. http://www.action-electronics.co.uk/art.php
DM
jason1111
« Reply #8 on: July 22, 2013, 02:08:03 pm »
yes  uses the motors for steering
that's a interesting read  thanks inertia
« Reply #9 on: July 22, 2013, 02:26:31 pm »
What bait boat is it could you please post a pic
jason1111
« Reply #10 on: July 22, 2013, 02:36:43 pm »
bsa lakestar boat
