Author Topic: LED's  (Read 4336 times)
F4TCT
  • I am not completely useless.......I can always serve as a BAD example
    • My Boat Builds
LED's
« on: August 05, 2013, 11:30:10 am »
Can anyone suggest where to buy some either 3mm or 5mm clear ultra bright L.E.D's from please? They must be 12v type.
Dan.
john44
Re: LED's
« Reply #1 on: August 05, 2013, 11:40:44 am »
Hi Dan,
have you tried component shop?
john
F4TCT
    • My Boat Builds
Re: LED's
« Reply #2 on: August 05, 2013, 11:43:12 am »
I have John, they don't seem to have 12v ones.
I used them for my tug and cant remember where i got them from. maplins dont seem to have any 12v clear, but they do have coloured.
mrturbo553
    • North Sea winches
Re: LED's
« Reply #3 on: August 05, 2013, 12:21:11 pm »
Dan do a search on flea babble 370690323037 use this item number
Check his other items or try model accessories Crewe ?
Over and out biggles !!!
Aid
Gone racing back in 9.5 sec
http://www.nswinches.co.uk
montessa315
  • I should do it which way?
Re: LED's
« Reply #4 on: August 05, 2013, 06:36:43 pm »
If you always do what you've always done, you'll always get what you've always got.
Re: LED's
« Reply #5 on: August 05, 2013, 06:54:15 pm »
LEDs will run OK on 12v with the right resistors.
Component Shop will advise.
irishcarguy
Re: LED's
« Reply #6 on: August 06, 2013, 01:49:05 am »
Hi Dan I got a large supply off fleabay both 3 & 5 MM with the resistors already wired they were dirt cheap too, look under LEDS, I think even the postage was free.led-world2007 is the fleabay company, 50 for $7.62. Hope this helps, Mick B.
Mick B.
F4TCT
    • My Boat Builds
Re: LED's
« Reply #7 on: August 06, 2013, 11:07:18 am »
rapid want about £35 including postage for 25 leds - dont think so like...
I'll just resister them myself using the component shop. Might work in my favour thinking about it anyway,
thanks for the replies.
Dan
plug
Re: LED's
« Reply #8 on: August 06, 2013, 10:33:35 pm »
Normaly get mine from here http://stores.ebay.co.uk/Handsignalman-LEDs?_trksid=p2047675.l2563 reliable seller and they come with resistors, worth a look
regards Jack.
Gerardy
Re: LED's
« Reply #9 on: August 19, 2013, 02:21:38 am »
Maybe you can try www.eastled.com   :P
MLT44
Re: LED's
« Reply #10 on: October 31, 2013, 09:58:08 pm »
Hi I use led on my tug lighting, if you have a word with the lads at Components, they will tell you witch resisters, and they will give you a colour code chart for the resisters
NEVER   GIVE   IN
StuartL
Re: LED's
« Reply #11 on: November 11, 2013, 11:08:14 am »
The resistor you need for the LED is relatively simple maths.  You need to know the current draw and voltage of the LED.  If you don't have this available assume 1.6v and 20mA (0.02A) and work from there.
If powering the LED from 12v you need to drop the voltage by (12v - 1.6v) = 10.4v at 20mA.
Ohms law says that V = IR, or R = V / I.  Resistance you need is therefore 10.4 / 0.02, or 520 Ohms.  Lots of people just use the readily available 470 Ohm resistor and accept that they're going to shorten the life of the LED a bit.
The same maths works with multiple LEDs.  If putting LEDs in parallel they each need their own resistor (i.e. 520 ohm each).  If putting LEDs in series you can power them all from one resistor.  The current remains the same but the voltage will change...
Four LEDs, each at 1.6v, would be 6.4v.  Voltage drop across the resistor would be (12v - 6.4v) = 5.6v.
The resistor can be calculated as:
R = V / I, so R = 5.6 / 0.02 = 280 ohms.
Note that you must have a resistor, even if you have enough LEDs to meet your battery voltage.  The resistor serves to drop the supply voltage if the LEDs try to draw more current, thereby self-regulating the current through the LED and avoiding the LED blowing up.
MLT44
Re: LED's
« Reply #12 on: November 11, 2013, 02:17:43 pm »
Hi. If you phone components they will tell witch res to use for 12v, the res are about 25pence each, and the res are pence each, they sell all the colours and sizes.
             Hope this is helpful. I buy mine in tens Dave
NEVER   GIVE   IN
MLT44
Re: LED's
« Reply #13 on: November 11, 2013, 02:25:01 pm »
Hi I made a mistake the leds are 20 pence the res are pennyes. Sorry senior moment.
NEVER   GIVE   IN
More Coffee
Re: LED's
« Reply #14 on: December 10, 2013, 07:55:24 pm »
led calculator....
http://led.linear1.org/1led.wiz
http://led.linear1.org/led.wiz
don't forget..
for a single Led on 12v supply with a proper resistor you may require 1/2watt resistors .. versus the 1/4 .
I know for a fact a 1/4 watt 470ohm resistor will get seriously hot supplying a ultra bright led on a 12v supply..
If your running a 12v pb  battery keep in mind the battery is considered dead ..If memory serves me correct 11.6 volt..
so your calculations should be based on 13v-13.6volt.. this also give you some overhead with the resistor. ..its not detrimental but the extra volt or two can stress the led and shorten its life..
The reason I mention this ..I often put a DC wallwart on my system to power the lights when company come's or just because I want to ..without going around re-installing the Battery for just a few hours..
Unless its a switched mode power supply chance's are the DC wall wart rated at 12v will often test upwards to 15v.. something to consider.
Page created in 0.128 seconds with 22 queries.
