Author Topic: A pair of suitable engines......?  (Read 3493 times)
tonyH
« on: August 08, 2013, 01:15:44 pm »
Hello all!
Project J is being planned and the optimum propulsion would be a pair of vertical twins attached to the two props. Hull length is about 3ft6inches with a projected displacement of about 29lbs.
A mate, being a retired machinist, has offered to make them for me, either from bar stock or from castings.
Anyone any ideas for suitable units.
One minor hiccup is that they will be in an enclosed hull so steam loss is a factor.
Tony
boatmadman
Re: A pair of suitable engines......?
« Reply #1 on: August 08, 2013, 03:23:22 pm »
How about a pair of these:
http://www.machinistblog.com/bogstandards-paddleduck-engine-plans/
I have made a pair, they are from barstock and turn out very nicely.
tonyH
« Reply #2 on: August 08, 2013, 07:12:02 pm »
Thanks Ian,
They look the sort of thing but if the height is the 4 1/2 inches in the preamble, they may be about 1/2 inch too high.
The cross section I have to work with is as below, with the maximum beam being about 9 inches, so the tumblehome limits a lot.
Tony :-))
malcolmbeak
« Reply #3 on: August 09, 2013, 10:42:57 am »
Tony
You might try the MB22. This is a slide valve twin of 3/8" bore and stroke. Height is just under 3". If you are a Paddleducks member, you can download the drawings and a building guide from the downloads section. The engine is non reversing, but I use a fwd/neutral/rev gearbox.
The photo shows the engine fitted with a pump, by-pass valve, displacement lubricator and a regulator.
Malcolm
SailorGreg
« Reply #4 on: August 09, 2013, 01:54:07 pm »
Does it have to be twin engines?  3'6" and 29 lbs are within the capabilities of just about any small vertical twin, and I'm sure you could arrange for it to drive twin props rather than one.  However, if there are other reasons for going with two engines, crack on - and do post a build log, we'll all be waiting with baited breath.
Greg
« Reply #5 on: August 09, 2013, 04:05:18 pm »
There was a description of a cross coupled Vee twin in Muddle Boats, if you go to the home page, the article may still be there.
  http://www.modelboats.co.uk/news/article/queen-alexandra/14470   look at photo 15.
tonyH
« Reply #6 on: August 09, 2013, 08:59:25 pm »
Hi all and thanks for the ideas :-))
The size is spot on Malcolm but I'd be worried about having no simple reverse control since the vessel is going to be a bu**er to drive at the best of times :embarrassed:
Same reason for two engines Greg. I used a single Hemmens set-up on a previous model (3ft/19lbs) with a Saito gearbox to the two contra-rotating props and while the power was OK the control was limited. Plus, I think that I need more than adequatepower with all the top-hamper that she carries.
I've a feeling I saw QE at Woodbridge last year Ian? Mechanically it's a belter but it's still a single setup {:-{
Part of the overall problem is the access because the intention is to split the hull at or near the waterline as discussed in other threads, so all the works are in the lower half and the fiddly bits are all on a lift-off unit up top (See pic) so small verticals are the target, especially since it would be so rude not to accept the offer from the builder %)
Regards to all
Tony
« Reply #7 on: August 09, 2013, 09:15:30 pm »
  It drives two propshafts?
tonyH
« Reply #8 on: August 09, 2013, 09:51:11 pm »
Aye but not independently. If I read the text correctly, the two crankshafts are connected to give contra rotation to the two shafts but at the same speed.
Or is it me...............?
Probably O0
Tony
« Reply #9 on: August 10, 2013, 02:16:37 pm »
     >>:-(  Yer didn't tell us that!
    Yer move the goalposts more times than Bernie Fricklstone.
  Regards  Ian.  {-)
tonyH
« Reply #10 on: August 10, 2013, 04:10:42 pm »
An I'm about 3ft taller than 'im as well!!!! ;)
Page created in 0.266 seconds with 17 queries.
