Author Topic: I.V. Bags  (Read 2936 times)
bbdave
I.V. Bags
« on: August 08, 2013, 08:16:33 pm »
I have been given some saline I.V. Bags 500ml are they any good for ballast bags? And if so how do I attach my fuel tubing?
Subculture
    • Dive-in to Model submarines
Re: I.V. Bags
« Reply #1 on: August 09, 2013, 05:49:32 pm »
They tend to be very strong, so provided the volume si adequate they should prove excellent for use.
You can join the tube i the bag to tubing on your pump etc. with a simple brass or copper joining tube.
bbdave
Re: I.V. Bags
« Reply #2 on: August 09, 2013, 09:25:22 pm »
Well as I need minimal freeboard 500ml might be enough I best get the scales out and do some figuring
Subculture
Re: I.V. Bags
« Reply #3 on: August 10, 2013, 09:45:57 pm »
Scales won't help much when you are working with wood. Most wood is much less dense than water, so if you use weight I would roughly double the amount of water you will need to pump onboard to submerge.
Gerardy
Re: I.V. Bags
« Reply #4 on: September 26, 2013, 10:03:23 am »
Wow.What is the project of your experinment?  %%
Page created in 0.021 seconds with 22 queries.
