April 19, 2021, 10:59:39 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem also on Facebook!
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Tugs and Towing
new big tug build
« previous
next »
Pages: [
1
2
3
4
Go Down
Print
Author
Topic: new big tug build (Read 22652 times)
para_handy
Full Mayhemer
Offline
Peterhead
new big tug build
on:
August 09, 2013, 11:14:25 am »
I am just about to start a new build, I bought a GRP hull on eBay see pics
the hull is 38" and is 1/32 scale can someone tell me what type and size of propeller
i should use.
Full Mayhemer
Offline
Meridian Line, Mouth of the Humber
Re: new build
Reply #1 on:
August 09, 2013, 11:21:58 am »
It would look like the choice has been made for you!
A four blade brass kort prop that will fit inside the nozzle
already fitted.
Up Spirits Stand fast the Holy Ghost.
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #2 on:
August 09, 2013, 11:26:30 am »
if i was using the Kort does the propeller need to be as large as possible the diameter of the Kort is 3"
Full Mayhemer
Offline
Re: new build
Reply #3 on:
August 09, 2013, 11:40:26 am »
If you contact Prop Shop and give them the Kort internal
diameter, hull size and motor, they will advise and supply.
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #4 on:
August 10, 2013, 12:27:43 pm »
This is the first build that i will keep a log I have been working on the wheelhouse
cutting the windows out first a drilled a series of holes then i used small files and
the corners where rounded using a dremel with a small radius sanding drum.
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #5 on:
August 10, 2013, 12:44:45 pm »
i don't know what i am doing wrong when posting as sometimes i get no reaction from the post button?
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #6 on:
August 10, 2013, 12:46:49 pm »
I am not shure which tug this is modelled on only thing i know is it was a liverpool tug open to
suggestion's please. I looked at this tug but i dont know enough as i am new to the tug scene
(see pics)
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #7 on:
August 10, 2013, 12:50:59 pm »
I think this may be the
Brocklehust
Brocklebank but I think the Kort nozzle is wrong i think it should have a rudder what type or design i don't
know any one out there have a pic of the right rudder for the job.
TugCowboy
Full Mayhemer
Offline
Hastings
Re: new build
Reply #8 on:
August 11, 2013, 03:58:22 pm »
Can't help you identify the hull but thanks for sharing your work so far and I look forward to seeing more.
Alex
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #9 on:
August 13, 2013, 02:30:33 pm »
I am about to put the wooden strip round the bullworks just below deck level, can you advise what type of glue to use or would it have to be something different so there is no reaction with glass-fibre.
wicker
Full Mayhemer
Offline
wick, caithness
Re: new build
Reply #10 on:
August 13, 2013, 05:03:29 pm »
I use aradite the long setting one
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #11 on:
August 18, 2013, 01:50:58 pm »
does anybody have the dimensions of the brocklhurst
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #12 on:
August 20, 2013, 01:24:48 pm »
due to a slip of the old grey matter i put Brocklhurst and it should be Brocklebank.
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #13 on:
August 28, 2013, 08:28:28 am »
I have finished the support for the deck and have fitted the prop shaft and the motor, I have fitted a Mtronik 550 motor but not knowing i think i should of have fitted a 3:1 gearbox or perhaps 5:1 gearbox maybe some of you shipmates can advise.
I will post pic's later today.
para_handy
Full Mayhemer
Offline
Peterhead
Re: new build
Reply #14 on:
August 29, 2013, 08:34:19 am »
here is the pics
Full Mayhemer
Offline
Re: new build
Reply #15 on:
August 29, 2013, 08:42:28 am »
Looking good there
Might I suggest a support under the forward end of the propshaft.
sailorboy61
Full Mayhemer
Offline
Wirral, UK
Re: new build
Reply #16 on:
August 29, 2013, 09:09:05 am »
some photos:
http://www.shipspotting.com/gallery/search.php?search_title=BROCKLEBANK
the tug is now owned my Liverpool maritime Museum, it might be worth dropping them a line to ask about further information.
Martin [Admin]
Administrator
Full Mayhemer
Offline
Peterborough, UK
Re: new big tug build
Reply #17 on:
August 29, 2013, 12:05:54 pm »
Whilst you've got easy access to the hull innards, sand down and smooth of the adhesive/filler while you can. You may also want to think about painting or sealing the GRP too.
Mayhem FaceBook Group!
Captbearuk
Full Mayhemer
Offline
Alhaurin el Grande, Spain
Reply #18 on:
August 29, 2013, 12:37:18 pm »
Martin,
I;m about to start on a GRP hull myself but I was only going to clean it out a bit and maybe a coat of paint. How, and why, should I seal it on the inside?
Glyn
Skimmer Fan
Full Mayhemer
Offline
Wigan
Reply #19 on:
August 29, 2013, 08:48:12 pm »
Para_Handy
I bought the a kit of a Liverpool tug off ebay that looks exactly like yours and came to the same conclusion as you that it was the Brocklebank. Because it was the closest picture to the kit I could find. It had been fitted with a motor and kort nozzle but no prop. I also found out if it is to be the Brocklebank I need to remove everything and start again. I will be very interested in your build as it is my firrst atempt at building a kit.
Skimmer Fan
para_handy
Full Mayhemer
Offline
Peterhead
Reply #20 on:
August 30, 2013, 12:16:12 pm »
I have started to spray inside of hull, I have used a dark color Humbrol nut brown.
(pics to follow)
thanks Martin for the advice
para_handy
Full Mayhemer
Offline
Peterhead
Reply #21 on:
August 30, 2013, 12:18:55 pm »
I have taken your advice about fitting a 900 motor with 3000rpm max
I opted for a 75 mm 3 blade propeller and this is also fitted.
para_handy
Full Mayhemer
Offline
Peterhead
Reply #22 on:
September 01, 2013, 12:19:10 pm »
I was wondering as i said i have purchased the 900 motor i see there is know flat on the spindle would you recommend grinding a flat on the spindle or would you leave it be.
Full Mayhemer
Offline
Newport. S Wales
Reply #23 on:
September 01, 2013, 07:30:16 pm »
I always grind a flat if there's none there.
Don't go too deep as it's not necessary.
Ken
Despite the high cost of living .......... It remains popular
para_handy
Full Mayhemer
Offline
Peterhead
Reply #24 on:
September 05, 2013, 08:38:29 am »
hi there i painted the inside of the hull nut brown did not like repainted white looks better i have started doing the bulwark's i have given them a light skim of car body filler to get them smooth.
Print
Pages: [
1
2
3
4
Go Up
« previous
next »
Tugs and Towing
new big tug build
