Author Topic: Chattering Servo  (Read 2637 times)
dhb141
Chattering Servo
« on: August 15, 2013, 03:11:50 pm »
I have an old 2 channel Sanwa Dash RC system which I’ve been using on a converted Seaport tug.   Just recently the rudder servo has started to, what I can only describe as ‘chatter’ when I switch on, even though I’m not touching the controls - moving the rudder slightly from side to side.    I’m a complete dumb brain when it comes to electronics so I’d be grateful if anyone can enlighten me as to what’s going on!   Thanks in anticipation.
Re: Chattering Servo
« Reply #1 on: August 15, 2013, 05:54:26 pm »
Either the servo has developed an internal fault, in which case it will require mending with a new one, or part of your wiring path between battery and the insides of the servo has grown a bit of black wire or if its a separate battery for the RX, the RX battery has gone a bit wonky on you.  The last could be a dud cell, or a bad connection.
« Reply #2 on: August 15, 2013, 05:55:57 pm »
If you switch your transmitter on first you should be OK.
If you switch the receiver on first it is looking for a signal
and sends spurious signals to the servo.
dhb141
« Reply #3 on: August 15, 2013, 06:08:55 pm »
Thanks to you both for your replies.   I won't be able to try out your suggestions until tomorrow and then I'll let you know what happens when I do.   Very grateful for your help.
« Reply #4 on: August 16, 2013, 02:58:50 am »
If neither of the above.I think I read somewhere about interference from other sources may cause this.
Could be a walkie talkie, microwave, or something else like a domestic wiring ring acting as an antenna, causing a problem.
A change location would  solve this.
dhb141
« Reply #5 on: August 16, 2013, 08:19:03 am »
Thanks to all three of you all is now ok.   I think the problem was a bit of everything you suggested because checking the connections (one a bit loose), re-routing the aerial (it had got tangled up) and moving the tug to a different room to try it out has cured the 'chattering'.   Thanks again for all your help - it's very much appreciated.
Page created in 0.044 seconds with 21 queries.
