Author Topic: My Nangee Build  (Read 4072 times)
furs307c
My Nangee Build
« on: June 09, 2007, 06:15:16 pm »
I bought the basic parts of the kit about a year and a half ago, and have been doing bits sporadicaly since then. As ive been at uni i havent been able to do mch recently. but this is the stage im at now.
Re: My Nangee Build
« Reply #1 on: June 09, 2007, 06:19:18 pm »
Looking good so far!
.... how many channels on your Tx?
        Will your boat also have Freeview?  ::) ;D
furs307c
Re: My Nangee Build
« Reply #2 on: June 09, 2007, 06:43:14 pm »
Its only gonna be  2 channel acoms job, cos thats what Ive already got lol, i need to fit the motor, shaft, coupling which i got from mmm, and i also need to fit the propeller a brass propshop one. Freeview TV in the wheelhouse  ;D, Theres loads of other stuff to do too. ::)
furs307c
Re: My Nangee Build
« Reply #3 on: June 10, 2007, 04:52:51 pm »
Im a bit of a noob as this is my first build ::). Im tring to fix the shaft etc in position, the angle seems a bit odd to me. Can anyone help  ;) is there an easy way of fitting these parts ???
HS93 (RIP)
  • I cannot spell , tough
Re: My Nangee Build
« Reply #4 on: June 10, 2007, 05:18:55 pm »
they can be single or twin screw, if its going to be single you will need to drill a hole a bit higher and try and get the shaft as parallel as you can to the bottom of the hull ,this is so the power is going back not pushing the hull up.get a prop and see how high you can put the shaft .  you could ask about to see if someone has a plan for it.  Peter
http://www.mobilemarinemodels.com/PDF/Nangee.pdf
furs307c
Re: My Nangee Build
« Reply #5 on: June 10, 2007, 06:18:59 pm »
Ive got a prop, and i have roughly lined it up it, it seems that if i put the hole any higher up the angle will be even steeper.Some more piccys below.
norry
Re: My Nangee Build
« Reply #6 on: June 10, 2007, 10:26:04 pm »
   ... Hi furs307c...
The top of the Kort Nozzle looks a bit far away from the hull...It shoud be no more than about 8mm from the hull to the top of the outside of the kort nozzle...
This should lessen the angle quite a bit...
 I hope this helps...
                                      ...Best Regards...Norry...
furs307c
Re: My Nangee Build
« Reply #7 on: June 10, 2007, 10:47:28 pm »
Hi, do you reckon i should just sand the top of the nozzle down in the area indicated in the picture below? btw cheers for the advice.
james
furs307c
Re: My Nangee Build
« Reply #8 on: June 14, 2007, 07:33:42 pm »
Right, ive done a bit of modification to the kort nozzle (e.g chopped a bit of the top of it ;D), ive also painted it. It seems to line up better now, ive still got to have it at a bit of an angle though because of the diameter of the motor i have (mmm car fan motor), which is quite large.
