it does seem that whenever you post a problem of something failing on a dragon to certain website tthe issue is ignored , i tried leaving querries in january when my hull split around the keel box and still not received any aknowledgment , improvments in the quality of the product will only make the boat even better surley ?
@triumphjon:
It may depend where you post it perhaps.
Also not sure whether you are referring to the designers or the distributors.
Re the designers - Mark Dicks (one of the three behind the product) is a regular or the Dragon Force thread in RCGroups...
I have also provided him some feedback on various matters on another forum (ShipShapeRC.com) that has been taken back to the manufacturers.
Re the distributors - I can only speak re Australia - I have had contact on a few occasions with Hobby Warehouse and they have been Ok.
I have also experienced the splits around the keel box, probably caused by rough handling on my part I think (travelling long distance in a vehicle, boat was in the back with lots of other gear).
It seems to have repaired Ok.
I used MEK (methyl ethyl ketone, a cleaning/primer fluid for plastic) and some light glass fibre, topped off with a bit of P glue (you will find these chemicals in the plastic plumbing section of your hardware store)
