Author Topic: 0.12 cc nitro - submerged drive. Straight shaft or parallel flexi?  (Read 1817 times)
dougal
On the face of it a straight shaft should offer less friction (more engine power to the prop)...but then some of the propeller thrust is wasted due to the shaft angle. Flexi-drive will create more friction (?) but with the prop parallel to the underside of the hull, it will be more efficient...?
I'm looking for the ideal set-up for a 0.12 Z Class OMRA boat.
With such a small engine, underwater drag/shaft diameter/drivetrain efficiency are crucial.
Any advice/ideas?
black magic racing
  • when winning is all . it stops being a hobby
Re: 0.12 cc nitro - submerged drive. Straight shaft or parallel flexi?
« Reply #1 on: August 28, 2013, 11:41:48 pm »
depends on the boat you are going to use :-))
FAST is never FAST enough
Black Magic Racing with BMPRS    Telford Model Boat Club
Birkenhead Model Power Boat club Vice Commodore
Tombsy
« Reply #2 on: August 29, 2013, 06:08:00 am »
I have a .12 in a JAE rigger that does close to 55mph with a flex but's a surface drive.
You might look at Piano wire drive with bearings as an option for your setup as well.
http://http://www.offshoreelectrics.com/products.php?cat=Piano+Wire+Drive+Systems
Brian
