I have a couple of questions regarding brushless motors in a dual drive configuration with one motor turning in the opposite direction.
1 Can two brushless motors be controlled with a single speed controller if you split the signal and use a controller with a high enough rating to satisfy the needs of both motors?
2 Can a brushless motor be made to rotate in the opposite direction by reversing two of the leads like in a DC application?
I am looking for information to set up two brushless motors, one turning in the opposite direction, both controlled by a single controller for use in a scratch built 1/16 th scale Air Sea Rescue boat, 62.5" OAL, and RTR weight should be in the low 20 lbs. range.
Thanks for the help, Larry
