Hi Guys, Good points!
Yes, the cooling water is warm -hot depending on the rate of steam through the engine. This water is 'clean, and could be used for preheated boiler fill, or re-routed back tot he main cooling tank.
Yes, the condensed water is 'oily.' which will always be an issue if you add oil to the engine steam 'in' (displacement or other lubricator). Some models have an oil seperator and then reroute the 'cleaned' water back to the boiler or holding tank. I will just have a waste water tank for this oily water. I think it would not be good to add oily water to the boiler, although I have seen this done many times in closed systems
One nice thing about the design is that it is easy to add a metering valve to the 'cooling water' side of the condenser, and therefore regulate the flow as needed. I estimate the present 'unrestricted' cooling water flow to be about 1.5 liters in 20 minutes. easy to calculate exactly, just have not done it.
The important thing is that the incoming steam is 'condensed' and thereby creating a slight vacuum making the third cylinder more efficient. The engine does run much better with the condenser operating at 'full cool'...but maybe there is a middle of the road or more efficient level of cooling to be obtained.
Right now, the cooling system is gravity feed for test setup. pic below. There is a provision for a water pump to be operated by the ST #2 cylinder....or I could add one off the crankshaft.....
I could also add a small radiator and fan driven by the crank to cool the 'cooling' water as is heads back to the holding tank.
I have read several books on condenser design, especially Audels Engineering and Mechanics Guide books 1-7. Some condenser design is based on boiler size, some books say it was the engineers perogative, and some have clear surface area minimum requirements (condenser must be at least such and such size for IHP etc.)
It seems better to have more than required surface area, without too much waste in materials and construct time so that you don;t fall short of creating the vacuum, and instead create the dreaded backpressure.
My steam exhaust inlet to the condenser is .25 ID and my condensed water outlet to the pump ID is .10. It is really cool to watch the increase in condensate as you increase the engine rpms and steam throughput, almost and instant change.
Audels also describes that the exhaust 'pipe' should have gentle bends and downslope, which I tried to follow.
