Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16   Go Down
Author Topic: Aziz - Hawaii build  (Read 106457 times)
david48
Re: Aziz - Hawaii build
« Reply #350 on: August 12, 2014, 09:16:59 am »
I have had a quick look there are a few marine chandlers on the island ,have you tried any of them for adhesive ,there is a post on here by Stan about builders adhesive ,search Sicaflex thy do sealants,adhesives, for real ships so thy should be good enough for a mode.
David
david48
« Reply #351 on: August 12, 2014, 09:18:08 am »
We did this at the same time you just beat me
David
GAZOU
« Reply #352 on: August 12, 2014, 09:29:21 am »
I lived 35 years ago in an island of the Caribbean, there was nothing, a plane a week the yachting sometimes stammered we waited that a visitor brings us screws or nails.
Then we made work our brains ...............
We looked how made the childrens of the soil .............
Now there are everywhere ship chandlers, especially to HAWAÎ
Look around you at my guy, looks! {:-{ {:-{ {:-{ {:-{ :(( :(( :(( :(( %% %% %% %% %% 8) 8) 8) 8) 8)  :o :o :o %) %) %) %) %)
seathug
« Reply #353 on: August 12, 2014, 05:33:23 pm »
Ok I understand im being a pain for everyone here lolz
But I have to ask the experts  since I have no idea what im doing
Pleaee accept my apologies :)
I think I need to be more patient with this build
And patience is what im lacking
If I need something and cant find it I get all frustrated
Any way
Like I said this is my first build
And im getting ahead of my self gluing things
Someone told me complete my electronics first
Before gluing the deck
More room for me to work on
Which I  believe his right
So ill work on my electronics first
Need to order my controller servo battery to complete it
Test run it on my tub  make sure everything works
 Then ill work on my deck
I will also order that uhu plasti glue
Thanx everyone for being patient with me :)
inertia
« Reply #354 on: August 12, 2014, 07:48:42 pm »
Exactly which battery is this? Your system needs a battery pack for the transmitter and also a main battery for the boat. The power for the receiver comes from the P102 by plugging in the two-wire flylead (read and black thin wires with black plug moulding) into the receiver where it is marked Batt. A separate receiver battery is not required. Take another look at the wiring diagrams I did for you (Stage 2).
GAZOU
« Reply #355 on: August 12, 2014, 08:27:37 pm »
To build the kit of the AZIZ is relatively simple if we follow scrupulously the note
Install the electronics without following the notes!
I laugh about it beforehand
A fireworks! {:-{
seathug
« Reply #356 on: August 12, 2014, 11:41:23 pm »
I meant my main battery which is 12v 12ah battery
I cant find a gel cell battery here in hawaii at the moment
They have to order it
Not in stock
The controller comes with a rechargeable battery from towerhobbies
But doesnt come with the servo
I can bundle up those things when I order it
slug
« Reply #357 on: August 13, 2014, 06:55:57 am »
try a 12volt disabled scooter battery...someone must sell them....tony  ps....keep going you will get there
slug
« Reply #358 on: August 13, 2014, 07:02:44 am »
just googled mobility scooters in Honolulu...quite a few.....tony
GAZOU
« Reply #359 on: August 13, 2014, 08:18:31 am »
There is no place for a battery of scooter
Get back batteries of drill / wireless screwing machine, condition them to occupy the available place
It is necessary to look around in the radio-controlled toys
slug
« Reply #360 on: August 13, 2014, 08:30:48 am »
sorry I was wrong...when he said a 12 volt 12ah I have 2 in my scooter...same size that I use in a 39 inch fishing boat...it is used for power as well as ballast....also I use 6 volt 4.5 amp hour given to me by a disabled person in other boats,wired for 12 volts in my nangee tug  regards tony
Model_Slipway
« Reply #361 on: August 13, 2014, 08:47:24 am »
Seathug
Nick at Harbormodels should be able to supply glues and batteries. They have been supplying kits, glues, accessories, electronics for the past 20 years.
Alternatively contact Floataboat in Australia, they are familiar with our kits.
Jackie
mrturbo553
    • North Sea winches
« Reply #362 on: August 13, 2014, 12:18:05 pm »
Another place for you to try would be fire alarm , burglar alarm businesses
They should use 12 volt 7 ah batteries
Good luck Aid
Gone racing back in 9.5 sec
http://www.nswinches.co.uk
seathug
« Reply #363 on: August 13, 2014, 07:23:05 pm »
Now why didnt I think of harbormodels O0 (thanx jackie) :-))
Yup harbormodels have what I needed
Im wasting time looking around here in hawaii
Of the things I needed
I dont want to waste anymore time
From now on ill just look online
Which brings me to another battery question
How much run time difference is 12v 12ah battery compared to a 12v 8ah battery?  With my set  up of electronics?
This might be hard to answer but
I just needed a wild guess?
Some say with 12v 12ah 2 to 3 hours
what about 12v 8ah?
2 hours run time is  what im trying to get
since itll be mostlt just floating a d watching it driftting away :)
Thanx
« Reply #364 on: August 13, 2014, 09:26:39 pm »
Rough order of magnitude an 8ah battery will run for 2/3 the time of an 12ah battery given the same load. HTH
seathug
« Reply #365 on: August 14, 2014, 05:45:08 pm »
In that case ill just go with 12v 12ah
Thanx
Any way hitec is back order from towerhobbies
Gotta wait again
seathug
« Reply #366 on: August 16, 2014, 06:47:43 pm »
David
Huh?
You have an aziz boat also?
Im slow builder hahaha
I have an excuse tho
My very first time to build anything
Any way my remote hitec6 is on back order from towerhobbies
Waiting waiting and more waiting
I should should be good on my next build
a tugboat :)
and that time I will make surr I have everything I needed before ill start putting it together
seathug
« Reply #367 on: August 23, 2014, 04:18:05 am »
Can someone help me decide on this two radios
I have no idea what the diffrence betwen this two radios
Except the price
Hitec Optic 6 Sport 6-Channel 2.4GHz Radio System SFE
price 132.00
Hitec Optic 6 Sport 6-Channel 2.4GHz Tx/2 Receivers
the price on this is 175.00
I have no clue which of this I should get
inertia
« Reply #368 on: August 23, 2014, 09:47:13 am »
price 132.00
Does that help? You really must give things a little more thought before you post.
seathug
« Reply #369 on: August 23, 2014, 10:19:28 am »
Hi inertia
I just wanted to make sure
I dont like second guessing  specifically when im ordering it online
Its better to ask the experts than making a mistake again :)
Thanx inertia
I dont need two receivers for now
I can always order those when the need for it arise
seathug
« Reply #370 on: August 27, 2014, 09:30:31 pm »
FOUND
Perfect cradle for my aziz :)
this thing folds when you put it away
50 bucks from kmart
seathug
« Reply #371 on: August 28, 2014, 08:39:48 am »
Finally my transmitter came in :)
Ordered it with my servo for the rudder
I must say it looks nice
but feels  cheaply made from plastic to me
it feels like I can crashed it with my barehands hahaha
Lots of reading to do again
Manual is 1 to 56
Crap I hate reading manuals
And seems like everyone is using go pro to taKe video
I pick up one for my self
Ill try it on my bristol bay first
Mad Scientist
« Reply #372 on: August 28, 2014, 10:33:34 pm »
That 'K-Mart cart' looks perfect - even has that piece on the back to hold the TX and whatever else you need. :-))
Tom
seathug
« Reply #373 on: August 28, 2014, 11:02:46 pm »
Yes its nylon and light weight it folds too
seathug
« Reply #374 on: September 05, 2014, 12:13:29 am »
Not bad if I say so my self
I like it clean or neat  looking
hate those exposed live wires
I like :-))
 how this action electronics goes together
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16   Go Up
