Author Topic: Eyelets- A link  (Read 3809 times)
Brian60
Eyelets- A link
« on: September 17, 2013, 11:42:07 am »
First off, apologies if this is the the wrong forum, but these are too good to miss for sail boats.
I have recently been scouring the internet for eyelets, really small ones for my sails. Well I found some at 1/16th diameter which are ideal and thought I'd share the link......
www.alchemyandice.com/1-16-brass-eyelets-2x1.5mm.html
These are super tiny and now I have to figure out how to cut  the holes in the sail cloth and then actually rivet them into place %% I bought a tube of 300, arrived in 4 days and I have a feeling I will never need to buy any more!
TailUK
Re: Eyelets- A link
« Reply #1 on: September 17, 2013, 12:45:04 pm »
Nice find!  I've just had a browse and there's loads of stuff suitable for boats.  Chain, eyelets and small bolts.
Arrow5
Re: Eyelets- A link
« Reply #2 on: September 17, 2013, 02:05:25 pm »
Also available in similar outlets are perforated metal  "spreader bars"  3 and 5 hole versions in plated metal. Lots of uses on model boats.
..well can you land on this?
roycv
Re: Eyelets- A link
« Reply #3 on: September 17, 2013, 02:16:54 pm »
Hi Bryan re putting eyelets into sail cloth.  I choose the spot for the eyelet dab on a small amount of superglue and allow to go hard.  Then use a drill by hand to open up the hole for the eyelet and fix the eyelet in place.  Practice on a spare piece of cloth first though.
good luck, Roy
regiment
Re: Eyelets- A link
« Reply #4 on: September 17, 2013, 03:04:22 pm »
i find a small hot soldering iron makes nice holes i found super glue and heat do not go together
Boomer
Re: Eyelets- A link
« Reply #5 on: September 17, 2013, 04:25:55 pm »
Good find thanks! I prefer using grommets on my sails. They are nearly impossible to find in less than 1/4" sizes. The grommet has two pieces which compress together eliminating the one rough side of an eyelet.
Boomer
rmaddock
Re: Eyelets- A link
« Reply #6 on: November 21, 2013, 03:52:30 pm »
Nice find Brian :-))
Page created in 0.03 seconds with 21 queries.
