Author Topic: mini cedar yacht 1metre  (Read 5526 times)
paul gutteridge
« on: September 18, 2013, 09:26:03 pm »
Hi hss anyone herd of a rc mini cedar 1metre yacht I have purchased off ebay
any information on the yacht would be much appreciated thank you.
especialy regarding the rigging. Type etc the sails made by house martin
ive been told the yacht is 6 to 7 years old plsnk on frame by paul lucas
mrpenguin
Re: mini cedar yacht 1metre
« Reply #1 on: September 18, 2013, 11:33:25 pm »
@paul:
You may get a better response if you are able to post some pictures of what you have.
There are many thousands of 1 metre yachts worldwide... the most common rigging setup is as a sloop or Bermuda rig consisting of one mast approximately in line with the front edge of the keel fin, carrying a jib and a mainsail.... the two sails are generally controlled by a single winch and the jib is self tacking.
Amateur at work...
hmsantrim
« Reply #2 on: September 19, 2013, 02:24:12 am »
Hi paul.
 the model is a French design and the plans are called   MRB 265 plan voilier mini cedar  they are from theFrench mag called
MRB Modèle Réduit de Bateaux  unusual  for me I can`t find the door for the plans section..
 http://mrb.rmf-boutique.com/forum-mrb/plans-et-documentations/15088-voilier-minicedar.html
 perhaps gazou can find for you
 frank
paul gutteridge
« Reply #3 on: September 20, 2013, 02:47:04 pm »
Hi all thank you for the kind info hope to put some photos on shortly
anyone know how to resize photos plx
cheers
« Reply #4 on: September 20, 2013, 05:05:30 pm »
We have a massive section on re sizing and posting pictures.
http://www.modelboatmayhem.co.uk/forum/index.php/topic,23.msg36.html#msg36
ken
mrpenguin
« Reply #5 on: September 20, 2013, 11:47:38 pm »
If you are using a Windows based computer, get yourself RoboSizer (free from www.robosizer.com)
I find it simple and automatic. You just post the pictures and it resizes them as you add them. You can specify a number of different resolutions.
For example I just attached the image below (the original is nearly 2000 kb) - Robosizer reduced it to the file size here (83Kb)
Amateur at work...
paul gutteridge
« Reply #6 on: September 22, 2013, 06:35:34 pm »
hi all here are a few photos any info on how to set up the rigging and sail on 1 metre plz
paul gutteridge
« Reply #7 on: September 22, 2013, 06:38:56 pm »
fitted sails ?
paul gutteridge
« Reply #8 on: September 22, 2013, 06:42:50 pm »
thank you mr penguin for your info resizing seems to have worked
can anyone tell me by looking at the rig setup on photos what the name is called for this kind of setup.
cheers
mrpenguin
« Reply #9 on: September 22, 2013, 11:42:32 pm »
@paulgutteridge:
Happy to be able to help re photo sizing, the small file limit on this forum is a challenge without a tool like RoboSizer.
The rig is the most common type - a Bermuda or sloop rig, consisting of two sails, a mainsail (the aft sail) and a self-tacking jib (the foresail).
The setup you have looks to be very well made and the rigging and the sails look like good quality materials.
From the look of it, everything is put together correctly. To get the boat sailing Ok, the sails will need some adjustment, it all looks a bit tight to me.... When not using the boat, let the tensions off a bit to avoid creasing the sails, also leave the hatch open so the boat is nice and dry inside.  (Make sure you seal that hatch up before you go sailing!!! White electrical tape around a flat lid or some sticky back would do the job and look Ok)
Here is a link to a video that is a good primer on sail tuning, it will get you started. The boat in the video has lots of adjusters, but you can achieve all the adjustments with the adjusters you have available. Do the adjustments in the recommended order.
http://www.youtube.com/watch?feature=player_detailpage&v=5JaeKpDvMl8
Also another one here, a bit long winded, but some good stuff in it...'
[EDIT - this second video relates more to construction than sail setting]
http://www.youtube.com/watch?feature=player_detailpage&v=TybDkWjawkc
Amateur at work...
paul gutteridge
« Reply #10 on: January 06, 2014, 07:01:27 am »
Hi all can anyone come up with any help or ideas for a different rig setup on my mini cedar yacht please ie deck fittings sheaves etc.
Thank you
