Author Topic: Robbe U47  (Read 10758 times)
pettyofficernick
Robbe U47
« on: October 01, 2013, 05:48:18 pm »
Good evening folks, I have just taken the plunge (pun intended) and bought a Robbe U47, but, there is no instruction book with it, so, I have a question or 2, first off, how do I get inside to charge batteries? How do I switch it on without having to take it all apart? The rudders are very loose, so I will need to sort those out, how do I get to them? Does anyone have a book I could buy or that could be scanned and emailed? I think that will do for now,
Many thanks in advance.
Nick.
TheLongBuild
  • Build em, and play hard..
Re: Robbe U47
« Reply #1 on: October 01, 2013, 08:50:56 pm »
Like wise I am too looking for the instructions and booklet for this model.
If it is built the same as the one I have there is an opening in the bow to insert an allen key, however looking at your pictures I can not see a join in the hull ?.
Oh yes I can I think at the rear of the sub. So yes you should have an opening in the bow. ( near the bottom)
pettyofficernick
Re: Robbe U47
« Reply #2 on: October 01, 2013, 10:15:57 pm »
Sorted, got hull split now, batteries on charge, hopefully will be able to take her for a sail tomorrow.....Could still do with instructions though.... :-)) :-)) :-))
Re: Robbe U47
« Reply #3 on: October 01, 2013, 10:21:21 pm »
Have you tried contacting Robbe?
They sent a replacement manual for my Seawolf in PDF form
hotline@robbe.com[/email][/size][/font]
pettyofficernick
Re: Robbe U47
« Reply #4 on: October 02, 2013, 12:23:06 am »
Thanks for that matey, I have had a lookat their site, but no download, I will send them an email.... :-)) :-)) :-))
pettyofficernick
Re: Robbe U47
« Reply #5 on: October 02, 2013, 09:57:43 am »
Morning folks, I have got her open now and all is looking good, batteries have been charged so its off for trials later. Here's some pictures of the insides for those interested... :-)) :-)) :-))
TheLongBuild
Re: Robbe U47
« Reply #6 on: October 02, 2013, 01:43:37 pm »
What are the main batterys ?.
TheLongBuild
Re: Robbe U47
« Reply #7 on: October 02, 2013, 01:44:34 pm »
have emailed you a copy  :-))
pettyofficernick
Re: Robbe U47
« Reply #8 on: October 02, 2013, 04:15:49 pm »
Main batteries are 2 x 6v 4amp SLA....Got the instructions, many thanks, I will post a photo of batteries in situ later when I fetch it in from the car.... :-)) :-)) :-))
pettyofficernick
Re: Robbe U47
« Reply #9 on: October 02, 2013, 07:26:02 pm »
Initial sea trials went well, a bit reluctant to dive beneath the waves, but made it eventually, bone dry inside when opened up for post sail inspection.
Sub driver
Re: Robbe U47
« Reply #10 on: October 02, 2013, 08:20:53 pm »
White ensign on german u boat.....nay nay and thrice nay . <*< <*<
pettyofficernick
Re: Robbe U47
« Reply #11 on: October 02, 2013, 08:26:49 pm »
The white ensign has been removed, I meant to do so before taking photos, but forgot in my excitement at getting it in the water. The lady I bought it from whose father built it, told me her dad did not like Germans, so he put a white ensign on it. I believe the RN did have a captured U Boat, that probably would have flown the white ensign. Incidentally, what colour is the U Boat ensign? BECC flags have one for U Boats, which is a white version of the Kreigsmarine ensign, as well as the standard red one.  :-)) :-)) :-))
hollowhornbear
Re: Robbe U47
« Reply #12 on: October 02, 2013, 09:36:52 pm »
you want the red one, i would suggest you need more ballast especially at the bows, if this is dynamic diving. I.E. forward motion takes her down no ballast tanks. best trim would be decks awash. hope this helps.
hollowhornbear
Re: Robbe U47
« Reply #13 on: October 02, 2013, 09:41:32 pm »
the u boat that flew the white ensign was U-570 renamed HMS Graph.
http://www.uboat.net/fates/captured.htm
Typhoon924
Re: Robbe U47
« Reply #14 on: October 15, 2013, 08:32:07 am »
Hi just spotted your post I have a set of instructions i can email to you, if required i have a U47 converted to static dive, bought the hull allready done just finished wiring and painting..
http://www.youtube.com/watch?v=HGKvhR3gwJM
pettyofficernick
Re: Robbe U47
« Reply #15 on: October 15, 2013, 09:18:22 am »
Good morning, many thanks for the offer, but I have now acquired a set of instructions. She is a poorly submarine at the moment, speed controller burnt out after an encounter with some blanket weed. Does converting to static diving require any drastic alterations? I may look in to it if it can be done without major disruption....
Typhoon924
Re: Robbe U47
« Reply #16 on: October 15, 2013, 09:34:00 am »
yes it does require a fair bit of work...mine was already done.
I use a micro gyros esc and a circuit breaker for added protection..my first Uboat was the dynamic dive, and now have two static dive subs which are great fun.
May be see you on the water one day, have you fitted a leveller they make dynamic subs much easier to sail and can hold a boat at periscope depth very nicely again Microgyros do one and I have those in both subs as do some of my pals..
all the best hope you get running again soon..
pettyofficernick
Re: Robbe U47
« Reply #17 on: October 15, 2013, 09:48:12 am »
Just looked on Microgyros site, the leveller, looks like it has been discontinued, so I will look elsewhere, I have  3 Microgyros esc's in surface boats, so I will pinch one of those. Many thanks for your helf,
Nick.
Subculture
    • Dive-in to Model submarines
Re: Robbe U47
« Reply #18 on: October 15, 2013, 10:00:09 am »
They haven't been discontinued. Call or email Mike via the links at his website.
Typhoon924
Re: Robbe U47
« Reply #19 on: October 15, 2013, 10:08:38 am »
As above call or skype Mike he is very helpful..
pettyofficernick
Re: Robbe U47
« Reply #20 on: October 15, 2013, 10:19:22 am »
Ok Thanks guys, maybe I looked at wrong page, there were a couple of submarine items that said discontinued, maybe I was looking at the wrong items.....
Subculture
Re: Robbe U47
« Reply #21 on: October 15, 2013, 10:31:54 am »
Those are legacy documents for earlier designs, which have been discontinued. The latest leveller can be seen at the bottom of the home page. It is a notable improvement on earlier designs, being considerably smaller and incorporating more functions.
pettyofficernick
Re: Robbe U47
« Reply #22 on: October 15, 2013, 11:01:26 am »
Spoken to mike, he is indeed most helpfull, he sent instructions by email, I will get one at the weekend, thanks for the recommendation chaps....
Typhoon924
Re: Robbe U47
« Reply #23 on: October 15, 2013, 01:35:52 pm »
most welcome good luck with the boat
R
pettyofficernick
Re: Robbe U47
« Reply #24 on: May 18, 2014, 05:16:16 pm »
Here is a short video taken by Mark on a cold winters morning of U47 underwater. Now swapped for a Sheerline Trafalgar in need of some TLC....    https://www.youtube.com/watch?v=D6nSc7UwVrA
Page created in 0.038 seconds with 21 queries.
