I am running a steam launch with the forward/reverse selected with a switch on the transmitter (2.4 GHz), so it's simply in one position or the other. A couple of times recently the servo operating the forward/reverse lever has started cycling back and forth without any command. Both times the boat was on its stand with the Tx close by and everything switched on. The only way to stop it seems to be switch the boat system off. Neither of the other servos in the boat (one of which is the same model as the problem one) are affected.
Is this a faulty servo or is there another reason for this? Or should I just keep the transmitter further away? Suggestions welcome.
Greg
