Author Topic: Robbe F 16 TX repairs  (Read 5298 times)
« on: October 26, 2013, 10:01:36 am »
 Is there anywhere an old F16 could be  serviced /repaired . The left joystick  appers to do nowt although the  Trimmer does.  The right  joystick appears ok albeit  extremely slow to return to central  but as its been lying dormant since the mid 90's probably clogged up with dust. Tried  opening up but  its reluctant to part  have removed the only clips I can see, Have tried to get a manual but none seem to be around. any advice  appreciated .
II have plenty of alternatives bit this has a we module for a Genoa sail fitted
Jay
Subculture
    • Dive-in to Model submarines
Re: Robbe F 16 TX repairs
« Reply #1 on: October 26, 2013, 12:24:40 pm »
I have an FC16, not an F16. the sets are quite similar though I think.
Sounds like a mechanical issue to me with the gimbals.
The control pots are common to both the stick and the trim, so if one is working and not the other, the link to the pot may be damaged. You can contact Robbe regarding spares, they are quite helpful I find.
« Reply #2 on: October 26, 2013, 12:50:05 pm »
Thanks  wouldn't mind if I could open the damn thing
spooksgone
« Reply #3 on: October 26, 2013, 02:22:33 pm »
I'm just about to take a hammer and chisel to mine, you can borrow it after if you like :-)
Subculture
« Reply #4 on: October 26, 2013, 04:49:10 pm »
Two removeable plastic tabs at the bottom of the transmitter case. They slide outwards, and once removed the back comes off- very easy to open and service.
« Reply #5 on: October 26, 2013, 05:22:34 pm »
Ahem! I had removed the clips but it would only open a couple of inches .Unsure how much pressure you need to split it
Subculture
« Reply #6 on: October 26, 2013, 05:28:35 pm »
Should come away easily, but it's possible someone may have done a mod or something.
« Reply #7 on: October 26, 2013, 05:38:17 pm »
If you have it open a couple of inches it is probably
as far as it will go until you disconnect the cables
connecting the two halves.
w3bby
« Reply #8 on: October 27, 2013, 12:07:16 am »
Robbe..... does this help??
« Reply #9 on: October 27, 2013, 09:18:25 am »
Thanks doubt Robbe would be much help I've trawled through their site already no mention of the F16 or its manual though I might give them a try .If it wasn't for the  little Genoa  fitting I would just dump it
« Reply #10 on: October 27, 2013, 02:01:21 pm »
Have you tried Futaba manuals website?
« Reply #11 on: October 27, 2013, 04:57:34 pm »
Yup Ned first  place I looked no use . I have managed to get it open can see no loose leads so might just leave it /I could  use another channel  but  whilst it might be  a good TX  its a clumsy big lump
Jay
thegrimreaper
« Reply #12 on: January 11, 2014, 06:25:42 pm »
Hi jaymac,
Did you have any luck in getting the FC16 to work ???
Regards Mark
Don't lie, thieve, cheat or steal. The Government do not like the competition.
« Reply #13 on: January 11, 2014, 06:51:02 pm »
Hi Mark  no I got it open but could not see the prob  so as  nowhere needing it just yet its in the glory hole
Jay
NoNuFink
« Reply #14 on: January 12, 2014, 03:38:26 pm »
You could try here
http://www.modelradioworkshop.co.uk/
I've no personal experience but I'm told he's very good
HTH
NNF
thegrimreaper
« Reply #15 on: January 12, 2014, 04:52:06 pm »
if ever you want to get rid please give me a shout with a price if you dont mind that is, I know its prosumtiouse of me but if one dosn`t ask ....
Regards Mark
