Author Topic: I had a thought smokers!  (Read 1003 times)
portside II
  • tugs at rest
« on: November 03, 2013, 02:33:53 pm »
Theres a guy down at the Goole pond who uses one of those electronic cigaretts.
These are inexpensive, about 20 and can be fed with flavoured stuff.
The thing is could they be used as a smoker for a model boat ,all they require is a vacuum
and they will produce a large amount of smoke or what it is.
Any thoughts.
daz
tugs62
Re: I had a thought smokers!
« Reply #1 on: November 03, 2013, 02:37:46 pm »
I bought one a while ago used it for a couple of weeks now its sat on my bench i had the same idea but not worked out how to do it yet but the flavoured stuff works great in a gruapner unit ive got in tug
GAZOU
« Reply #2 on: November 03, 2013, 02:53:47 pm »
the liquid is too expensive for this use  {:-{
if you buy the cheap liquid is harmful <:(
 the liquid can make you soar ............. (Grass ) 8) %)    :si::si::si::si::si::si:
tugs62
« Reply #3 on: November 03, 2013, 07:31:01 pm »
Just mix some with wd40 and still works a treat in the tug I might as well use it like this as don't like smoking it any way :-))
