Author Topic: Prop shaft noise  (Read 3240 times)
Phil56
Prop shaft noise
« on: November 04, 2013, 01:07:17 pm »
I have twin prop shafts in a glass fifer hull one makes more noise than the other when running at all speeds .I have checked for shaft straightness and alignment
Brian Roberts
Re: Prop shaft noise
« Reply #1 on: November 04, 2013, 01:11:37 pm »
Try greasing the prop shafts.
Brian
« Reply #2 on: November 04, 2013, 02:20:55 pm »
Just a little grease to start with.
If you don't have grease to hand, use any machine oil, 3-in-1, car engine oil, olive cooking!
Arrow5
« Reply #3 on: November 04, 2013, 02:38:37 pm »
Almost certainly the universal joint, they are notorious if misaligned or sometimes poor manufacture. Try a silicon tube over spline instead of centre section if it is a Huco type for non-alignment error. Plus all of the above ,grease, oil etc.
..well can you land on this?
Phil56
« Reply #4 on: November 05, 2013, 12:44:24 pm »
Sorry should have said tried oil and then grease after cleaning off the oil .The universal joint looks ok but will swap them over to check
Sandy
« Reply #5 on: November 12, 2013, 09:19:34 am »
I think you implied this but just swap the universal joints between the two shafts and see whether the noise goes with the joint or stays with the shaft.
sparkey
« Reply #6 on: November 12, 2013, 11:39:48 am »
 ok2 The fact that you have a glass fibre hull will magnify the sound 10 times,even the slightest misalignment will sound worse than what it is,try lining the hull with polystyrene this will kill all shaft and motor noise and help with floatation,Ray. :-)) :-)) :-)) :-))
« Reply #7 on: November 12, 2013, 12:06:15 pm »
Is noisy in water as well as out?
john44
« Reply #8 on: November 12, 2013, 12:23:13 pm »
Also check the brass  part of the coupling on occasion I have had some out of center.
Thus causing vibration.
john
oldiron
« Reply #9 on: November 13, 2013, 11:41:32 am »
 I quite agree with ARROW. The "universal" is the biggest noise maker on most model boat drive systems. Check out this thread for more insight into the problem: http://www.modelboatmayhem.co.uk/forum/index.php/topic,33847.0.html
Also take a look here for some other suggestions: http://www.modelboatmayhem.co.uk/forum/index.php/topic,42205.msg427025.html#msg427025
« Reply #10 on: November 13, 2013, 06:29:32 pm »
If they are universals with just the one bendy element, be aware that they are not very universal, any misalignment will produce noise.  The suggestion was made earlier that a length of silicone rubber tube be used instead.  It should help eliminate at least one problem.  There is nothing in the rule book that says that any problem has just the one source, though.
Page created in 0.029 seconds with 21 queries.
