Pages: [1] 2 3   Go Down
Author Topic: AZIZ Build  (Read 21322 times)
Darksheer
AZIZ Build
« on: November 08, 2013, 02:13:48 am »
Morning everyone
Finally started the aziz and its a fantastic model
thank you to everyone who gave advice
first photo installing the running gear
one prop almost ready for gluing
seathug
Re: AZIZ Build
« Reply #1 on: November 08, 2013, 04:21:46 am »
Wow I just got my aziz delivered today
may I know what glue youll be using for the drive shaft and kort nozzle?
Thanx
Darksheer
Re: AZIZ Build
« Reply #2 on: November 08, 2013, 04:25:22 am »
im going to use 5 minute epoxy and thick zap glue i roughened up the metal alot after cleaning it so i get a good bond  least thats the plan
seathug
Re: AZIZ Build
« Reply #3 on: November 08, 2013, 08:30:59 am »
I was thinking of using jb weld cor the kortnozzle hahah
tomorrow ill start with the   cradle hopefully if im not busy
was accurate those marks for the nozzles and drive shaft?
Im thinking of re measuring it to make sure its on the right spot
Re: AZIZ Build
« Reply #4 on: November 08, 2013, 08:44:09 am »
Measure twice, cut once.  :-)) :-))
seathug
Re: AZIZ Build
« Reply #5 on: November 08, 2013, 08:46:34 am »
 :-)) exact da mmon do
what motor will you be using?
Jerry C
Re: AZIZ Build
« Reply #6 on: November 08, 2013, 08:47:55 am »
I found I had to extend the "A" frame slots forward by 1/8" to get correct distance between "A"frame and rudder tubes. See my blog if the build below.
Jerry.
seathug
Re: AZIZ Build
« Reply #7 on: November 08, 2013, 08:54:40 am »
Hi jerry thanx for the blog
Man I dont have any tools to make the sadle haha
opps
should I make my own thread for the aziz
I feel like im hijacking this thread :)
adamD98
  • Born free, forced to work!
Re: AZIZ Build
« Reply #8 on: November 12, 2013, 01:44:44 pm »
Jerry.
 I'd be inclined to agree with this, I remember having to move my A frame slots forward but I couldn't tell you how much.
 Nice start to your build, good luck and enjoy the rest!
Cheers,
-Adam-
NFMike
Re: AZIZ Build
« Reply #9 on: November 12, 2013, 03:52:00 pm »
Yes, I found the markings on the hull and the drawing dimensions didn't quite match, for both the A-frames and propshaft openings.
You'll need to make some choices yourself, but making sure everything is true and free before gluing is vital.
Darksheer
Re: AZIZ Build
« Reply #10 on: November 14, 2013, 06:45:23 pm »
little update
i now have a intimate understanding of the term "fiddly"
finally got both shafts epoxied in and lined up "i hope" they look good and the numbers all match
it was a case of measuring 20 times praying once and gluing after applying gobs of tape to hold everything in place
here are the pictures
the Hull now gets put aside untill the speed control and bow thruster arrive from UK
going to work on the bridge and start applying the hull framing
thanks for looking
Darksheer
Re: AZIZ Build
« Reply #11 on: November 19, 2013, 04:30:15 am »
superstructure coming along well
this kit continues to amaze me with its quality and ease they have done a fantastic job
more to follow during the week
retirement is a wonderful thing
smileyjon
Re: AZIZ Build
« Reply #12 on: December 05, 2013, 05:30:47 pm »
Ah.....Two engines, two props, two sets of electric stuff
I'll keep an eye on this one
Darksheer
Re: AZIZ Build
« Reply #13 on: December 05, 2013, 09:29:37 pm »
just waiting on the bow thruster
plastic was a little brittle and cracked so that took time to sort
some sub components started
working anchor
lighting kit
fire monitors
going to run off a single speed speed control for now
Re: AZIZ Build
« Reply #14 on: December 06, 2013, 10:54:14 am »
Tip ................
Regarding the smoke stacks, it is easier to fit the ladder rungs and ancillaries before you secure them to the cabin.
ken
Darksheer
Re: AZIZ Build
« Reply #15 on: December 06, 2013, 02:44:24 pm »
I havent attached them yet thankfully as im waiting for the smoker to arrive so i can run the piping
thanks for the tip much appreciated
iantype-r
Re: AZIZ Build
« Reply #16 on: December 08, 2013, 05:12:19 pm »
Looking forward to seeing more progress pics of this,
Darksheer
Another Update
« Reply #17 on: December 31, 2013, 05:50:39 am »
Still waiting on the last of the components "bow thruster and lights" to arrive so i can do the running gear up
did more work on the superstructure and drilled a tonne of holes
apologies for poor lighting my main work light just burned out
Darksheer
Re: AZIZ Build
« Reply #18 on: January 01, 2014, 03:32:49 am »
bow thruster came in the post today and was promptly installed
with that out of the way the motors are next along with the speed controls and other gubbins
Re: AZIZ Build
« Reply #19 on: January 01, 2014, 11:15:43 am »
What sort of angle is there on the motor mount ?  It does look too much towards the horizontal.
Ken
Darksheer
Re: AZIZ Build
« Reply #20 on: January 01, 2014, 05:53:40 pm »
its braced at a 45 degree angle so i can get at it if anything goes wrong a few people in my club have had problems with bow thrusters and were unable to get at the unit to fix them so they left them disabled  which is why i mounted it this way
Re: AZIZ Build
« Reply #21 on: January 01, 2014, 08:12:19 pm »
45 degrees back might work out OK, only the picture looks more like 80 degrees so I was worried.
The seal will stop water ingress to the hull so that's fine.
ken
NFMike
Re: AZIZ Build
« Reply #22 on: January 01, 2014, 08:55:47 pm »
Looking at the MS drawings I'd say 60° would be better, to line up with the deck opening under the superstructure. But from the photo it looks like you have mounted it a bit further forward, so 45° might be about right. (The main thing is to be able to get a screwdriver in to the mounting flange screws.)
Darksheer
Re: AZIZ Build
« Reply #23 on: January 01, 2014, 09:22:40 pm »
here is a better shot of it with the deck tacked in place
its very easy to get at as far as i can tell
and yes it is mounted much closer to the bow about 2 1/2 inches closer than what the plans state
motor mounts in as well
Darksheer
Re: AZIZ Build
« Reply #24 on: January 05, 2014, 12:57:01 am »
did more work today got the working anchor assembly in place and fitted
Pages: [1] 2 3   Go Up
