Author Topic: scale in photo shop print  (Read 2806 times)
LarryW
« on: November 30, 2013, 05:24:05 pm »
             Help to change scale in photo shop to printer, need to add to print out  113% from1.28 .........can you help Larry
never pass a skip
Umi_Ryuzuki
    • Models and Miniatures
Re: scale in photo shop print
« Reply #1 on: November 30, 2013, 05:42:52 pm »
Change the image size 113%
 ok2
« Reply #2 on: November 30, 2013, 05:51:07 pm »
That doesn't always work if the calibration of the machine is a bit out. I would draw a line on the plan say 20cms long with short verticals at each end and say you want that line to be exactly 22.6cms long on the finished print. Then you will know exactly what you are getting.
grendel
« Reply #3 on: December 01, 2013, 10:54:03 am »
dont forget, when you print there can be up to 5mm difference over each metre of paper variation - just due to the humidity of the paper, something that a lot of perfectionists in the architectural world seem to forget when claiming drawings are 'to scale' I dont know of any printer manufacturer that claims better accuracy. It can be done better but only with  a full calibration run just before the required print, even then if you move the print to a more humid location, you stand the chance it will stretch by up to the same 5mm from true.
on some machines they express it as a scale when printing or copying, so 113% would equate to 1.13 as a scale.
Grendel
« Reply #4 on: December 01, 2013, 12:27:33 pm »
Architectural drawings usually specify that written measurements should be preferred over scaled ones. I suppose that if they aren't then that is when you get a leaking roof.....
LarryW
« Reply #5 on: December 01, 2013, 03:09:10 pm »
  Hello . Thank you now forget the tec stuff, get back to the thread , tell me answer cheers Larry...
never pass a skip
« Reply #6 on: December 01, 2013, 03:24:25 pm »
Umi gave you the answer  :-))
LarryW
« Reply #7 on: December 01, 2013, 03:42:48 pm »
      done that don't work  {:-{  Larry
never pass a skip
vnkiwi
« Reply #8 on: December 01, 2013, 06:13:05 pm »
Larry,
are you trying to get 113% larger than 1.28 on your printer?
If so try 1.45 on the printer.  (1.28 x 1.13)
check thou, because math's was never my strong subject.
cheers
vnkiwi  :-))
Page created in 0.025 seconds with 17 queries.
