Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 227636 times)
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #475 on: March 10, 2017, 04:49:31 pm »
Looking great Danielle
Colour brings the build
to life. :-))
missyd
« Reply #476 on: March 14, 2017, 03:55:39 pm »
Thanks a lot Ned!  :-))
Railing on the bow was made today ... came out nicely!
Finished ...
Two small details added. Don't know how to call them ... profiles to prevent water dropping into the stairwell and to the left and right of the deck.
Then I repainted the interior of the wheelhouse. Its iron oxide red. I will add the wood grain by drybrush technique. Then it will look allright!
Danielle
« Reply #477 on: March 14, 2017, 07:24:55 pm »
Hi Danielle. Stair coaming springs to mind, I mean logically it is a coaming of sorts, just a shallow one.
Aw, she's a neauty. I like the realistic way you are using baulks of timber to prop stuff up:O)
RAAArtyGunner
« Reply #478 on: March 15, 2017, 12:11:27 am »
It will also help support the rail in heavy weather  %)  %)
Looking Good :-)) :-))
missyd
« Reply #479 on: March 15, 2017, 04:28:03 pm »
Thanks a lot to you two!!!  :-)) :-))
Another detail added at the end of the deck ... then some white and blue color on deck ... nearly finished it is!
Drilled all the holes for the railingposts.
The upper deck ready for the varnish.
And the boat from the top ...
I like the railing at the bow!
Danielle
« Reply #480 on: March 15, 2017, 10:09:28 pm »
You went all 'Yoda' there Danielle! The railing on the bow is very neat. Did you do them from plastic or metal? If the former then extra kudos to you as plastic can be a nuisance especially when under tension.
missyd
« Reply #481 on: March 16, 2017, 04:33:57 am »
The plan was to make it with copper wire but in the end I used ABS profiles. Its not as sturdy as a copper one but it does not break easely. I did the same with the Cornelia Marie. But the Cornelia Marie can't be lifted and handled as good as the N. Loredana.
Danielle
missyd
« Reply #482 on: March 16, 2017, 04:14:08 pm »
Last brushes of blue paint and varnish on the upper deck (sorry no pic).
Then off I went with the railing.
Left side done ....
Right side done as well!
The next days will be spent with adding the nex two rows of the railing.
I am happy with the look of it.
I must say I should keep her for myself! There is no other fishtrawler in the world with such elegant lines as the the ones made by the Cantiere Navale Ippolito in italy!
Danielle
« Reply #483 on: March 16, 2017, 08:46:35 pm »
Though i like the shape of most fishing vessels because of their squat and tubby shapes, the Nuova is another thing altogether, and like mentioned before, they manage to combine the lines of a cabin cruiser with that of a trawler.
Gorgeous wirk Danielle. I can understand your retisence to part with her after all your hard work. Is it going far away from you?
RAAArtyGunner
« Reply #484 on: March 17, 2017, 12:51:32 am »
 Just think of how much improvement you can do on the second one  O0 O0
missyd
« Reply #485 on: March 17, 2017, 03:36:59 pm »
It will go to Rimini in Italy. To the son of the ex-owner.
I am not sure if I would build another one. There is a big access problem with the long upper deck ....  {:-{
Maybe I would build the hull again but leaving the deck with the netwinch at the open like they have on trawlers in sicily. It would be an option.
Last working day .... time to make the second row of the railing.
First I made a little helper ....
In use .... rather good thing even if some of the profiles where welded with aceton in place without the help of it.
A part of the third row where made just to show you how it will look in the end.
And a pic of todays work ....
Danielle
« Reply #486 on: March 17, 2017, 05:09:39 pm »
Well now, what a simple, yet brilliant idea that is - it kind of looks like a forklift holding the bar steady.
Did you make another "helper" for the lower bar as well ?
missyd
« Reply #487 on: March 17, 2017, 06:02:01 pm »
For the lower bar I have 2 simple 11x11 fir profiles ... maybe I do another helper I don't know.
Danielle
missyd
« Reply #488 on: March 18, 2017, 04:36:29 pm »
Ufff .... the railings are finished.
Left side
View to the bow
And as usual the ship from above picture
Danielle
jarvo
  • Etherow model boat club
« Reply #489 on: March 18, 2017, 06:24:48 pm »
They look amazing, 'straight to!!!'  no wonder you are out of pull, must have been a grueling day
Mark
Tugs are for pulling
missyd
« Reply #490 on: March 20, 2017, 05:40:22 pm »
Mark, actually it went rather well without to much hassle. Must have had a good day!  ok2
New week other details to be made .... the life raft canisters and its holder ....
Didn't have a 20mm rod but 1/2 ones ... so glued them together which gave me a line in half to put additional details on it.
The holder is made of ABS cut in half.
All parts before glueing together.
Check if everything is OK.
Some details added.
More details added ....
Just slapped some color on it ... will sand it down tomorrow.
And put it on the deck of the N. Loredana.
Danielle
missyd
« Reply #491 on: March 21, 2017, 05:01:56 pm »
Some more color on the roof of the wheelhouse and the liferafts...
Started to make some details in the wheelhouse.
An italian modelling friend made these nice labels for the liverafts.
Wonderful detail! And wait! There's a special detail I have to show you after the next picture.
The label has the right name on it!!!!
Danielle
« Reply #492 on: March 21, 2017, 07:51:00 pm »
That is such a special detail! You are doing some very inspiring work Danielle especially in the wheelhouse.
missyd
« Reply #493 on: March 22, 2017, 02:03:11 pm »
Thanks a lot!!!! I give my best!!!  :-))
Today I painted the stuff in the wheelhouse...
And used some printed out pics from the Furono and other homepages.
Glued yesterdays work in place on deck.
Danielle
missyd
« Reply #494 on: March 23, 2017, 05:22:25 pm »
Finished the wheelhouse electronics yesterday evening ....
Today its time to finish with the color of the hull .... first I used the superb masking tape from Tamiya and then a normal masking tape from the DIY shop. I always use the Tamiya masking tape as I slap a lot of color on the hull and even after 4-5 times you can remove it without problems.
2 times white color ...
Another 2-3x and FINISHED!!!
After a couple of hours I varnished the hull down to the yellow line.
Danielle
« Reply #495 on: March 23, 2017, 08:40:14 pm »
All done? If so thankyou for a winter's worth of interesting and entertaining work. From the ply frames to the excellent internal details in the wheelhouse and on the deck.
missyd
« Reply #496 on: March 23, 2017, 09:21:24 pm »
hehe ... the hull is finished .... still have to do the radars and lights and all the electronicsand the nets and fenders and  ....  ok2
Danielle
« Reply #497 on: March 23, 2017, 09:25:57 pm »
You tease  :} :}
MikeK
  • Utter Bloody Chaos !!
« Reply #498 on: March 24, 2017, 07:15:05 am »
Another beauty Danielle ! The boat I mean, not you  {-)
Does the chap that you are building it for know of this record on MM of the build ?
missyd
« Reply #499 on: March 24, 2017, 03:36:29 pm »
Mike I think he knows MM ....  ok2
Today story has the title: THE TWO DOLPHINS!
Yes there are two dolphins on the exhaust stack.
I wasn't sure how to fabricate them. First I printed them in the right size on paper.  Then I glued the paper on a piece of 1mm ABS sheet. First I tried to cut it out with a knife (dolphin to the right) and ended up in using my Proxxon bandsaw (the left one)! Worked out very well and everything was ready for sanding in under 6 minutes ....
The result is rather nice ....
Looks ok on the exhaust stack.
Ready for paint!
Now the upper deck is 99% finished.
Danielle
Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28   Go Up
Page created in 0.06 seconds with 21 queries.
