....the Australian supplier after reading my plight has free supplied a replacement 750 mm length of 5/32" OD x #24 brass tubing
It is a different batch lot as the replacement has microscopic longitudinal die marking on the OD which was not apparent in the original tube piece
Best news is.........the replacement...well.......
.it tins...it sweats .....it solders perfectly........
Having said this....none of the comments offered explain the non solderability of the original tube piece..... .............Derek
BTW...the following are the calcs I use...which essentially are the same as shown by Sandy a few days back......
_____________________________________________________________________________________________
Barlow's formula can be used to estimate burst pressure of pipes or tubes.
P = 2 s t / (do SF)
where
P = max. working pressure (psig)
s = material strength (psi)
t = wall thickness (in)
do = outside diameter (in)
SF = safety factor (in general 1.5 to 10)
The Barlow's estimate is based on ideal conditions at room temperature.
Material Strength
The strength of a material is determined by the tension test, which measure the tension force and the deformation of the test specimen.
the stress which gives a permanent deformation of 0.2% is called the yield strength
the stress which gives rupture is called the ultimate strength
s=25,000 PSI, t=0.014, do=0.15625 [5/32OD],
SF=2
or
SF=5
P= 2^25,000^0.014 /0.15625^2 = 2240 PSI @ 2:1 FOS
P= 2^25,000^0.014 /0.15625^5 = 896 PSI @ 5:1 FOS
