Author Topic: Water Cooled Back Plate on Nitro engines  (Read 934 times)
bj
« on: December 20, 2013, 03:15:47 PM »
Looking at the Weston UK Marine Engine site I noticed that their range of marine engines have water cooled back plates. See: http://westonuk.co.uk/westonuk2_101.htm
Anyone come across water cooled back plates before? Any major advantage? Any opinions?
Re: Water Cooled Back Plate on Nitro engines
« Reply #1 on: December 20, 2013, 04:52:11 PM »
Can't get the link to work on my fone but found the site.
Anyone on here using Wundabond?
Leaky Bottom
« Reply #2 on: December 20, 2013, 05:59:33 PM »
Yes I've got a old OS max 10 & 30 with water cooled back plates.
Don't know of any advantages thou
"Leave me alone I know what I'm doing"
tr7v8
« Reply #3 on: December 20, 2013, 08:58:29 PM »
Water cooled backplates will improve overall efficiency. The charge through the carb goes via the crankcase & up into the ports. By cooling the backplate you'll increase the charge density increasing the performance. A side benefit is that if the exhaust is that side then you'll reduce the temperature gradient across the cylinder which improves the piston fit & reduces the chances of a hot seize.
Jim
