Author Topic: Anyone any experience of Planet T7 ?  (Read 2210 times)
spearfish99
« on: December 31, 2013, 12:52:04 pm »
Hi Guys,
   Just asking if anyone has any experience of using a Planet T7 set up.  I am currently building a Challenger 43 to be run on a CMB21 using a Mocom gearbox for next years AA events.
  Given that I haven't used gears before , which is a challenge in itself, the CMB comes with a carb that has both throttle and mixture control. The mixture really needs to be controlled off of a proportional channel. My Futaba 2.4ghz kit all has channel 5 or 6 on switches . My old 40mhz 6EX has a channel 6 rotary control, if I can get hold of a 6 channel rx to utilise it but I would prefer to stick to 2.4 to avoid crystal swapping issues in a rather tightly postioned radio box.
I have looked for a reasonably priced alternative and few cheapish set ups have rotary or sliders on the additonal channels. The Planet T7 does have c6 on a rotary control and would be ideal EXCEPT for the dire warnings about it not being a "full range" set and having a max range of 100m.  Personally I believe that this range is very conservative (probably due to litigation issues that might arise nowadays) .Also I doubt that I could even see to control it much beyond 100m due to the joys of old age!
Seriously , has anyone experience of using any of the Planet systems for racing on our usual venues, had or heard of any range issues or can offer any alternative ideas?
unbuiltnautilus
Re: Anyone any experience of Planet T7 ?
« Reply #1 on: December 31, 2013, 01:42:44 pm »
Dont use a Planet set for something like a power boat. Although I have tested one out to 150 metres line of sight, at ground level with no problems, their main issue is the slow re-bind time. typically 4 to 5 seconds, not good when hacking round a lake at speed. Our local clubs Fast Electric boys have switched to other makes because of this, I tend to agree.
Try looking at the Etronixs sets distributed by CML Distribution, good mid-priced sets configured for racing, accept no orange, £30 or plug it into your computer to set it up, chinese tat, do the job right....
http://www.cmldistribution.co.uk/cml_category.php?catId=269&range=RACING
inertia
« Reply #2 on: December 31, 2013, 02:14:58 pm »
Spearfish
The Futaba 6J 2.4GHz has a rotary-controlled auxilliary channel, although you only get four channels if you operate it in one of its transmission modes (I forget which). The Hitec Optic 6 2.4 GHz also has proportional extra channels; this seems to be quite a popular set with the offshore boys. Neither set is very cheap but both are computer radios with full range - "budget computerised sets" would be a good description. The computer utilities can be very useful e.g. end-point adjustment, exponential and differential throw. so don't dismiss them as expensive luxuries. I've owned both types but I kept the Hitec because the 6J doesn't work with the ACTion P94 unit. This is not a problem with i/c power.
Suit yourself.
DM
Page created in 0.098 seconds with 22 queries.
