Pages: 1 2 3 4 5 6 7 [8] 9 10 11   Go Down
Author Topic: Shapeways.com - 3D Printed Parts  (Read 120656 times)
rsm
Re: Shapeways.com - 3D Printed Parts
« Reply #175 on: October 28, 2014, 09:13:02 am »
I would definitely buy the STAAG 40mm mounts if you were able to produce them. Got my 3 pounder saluting guns already and they are excellent. Cheers.  :-))
Roger
Marmoi
Marmoi
« Reply #177 on: November 05, 2014, 02:57:08 pm »
Marmoi
« Reply #178 on: November 05, 2014, 02:59:52 pm »
And for something a bit more up to date - The Sea Ram RIM 116
1:96
https://www.shapeways.com/model/2830677/sea-ram-stl-rim-116-kit-1-96.html?materialId=61
raflaunches
  • The Penguins are coming!!!
« Reply #179 on: November 05, 2014, 09:30:10 pm »
Had my 12pdr and 3pdr guns arrive last week, very impressive, one of the 3pdrs is sitting on top of my gun turret on my majestic class battleship. Excellent service Mark! :-))
Nick B
Illegitimi non carborundum!
mudway
  • Model Boat Mayhem is Great
« Reply #180 on: November 05, 2014, 09:33:47 pm »
I got my lovely 3 pdr saluting guns the other day but must have missed the post about 12 pdrs being available.  :((
Marmoi
« Reply #181 on: November 07, 2014, 08:13:43 am »
To go with the Leander bridge top, there is now a County class bridge top as well
1:96
https://www.shapeways.com/model/2833746/county-bridge-top-1-96.html
I have not forgotten the S100 bridge, its just taking a bit of serious geometric work to get it right!  %%
Marmoi
« Reply #182 on: November 07, 2014, 11:10:40 am »
If anyone is going to the Leamington - International Model Boat show - this weekend, I have a few of my models on the Burton stand if you want to pop along and have a look. I will be there on Saturday and Sunday if you want to have a chat.
Mark
Marmoi
« Reply #183 on: November 07, 2014, 07:40:25 pm »
The S100 1:24 bridge is drawn up now, can someone check these dimensions?  %)
Paul Swainson
    • My build of HMS Illustrious 87 1939-1942
« Reply #184 on: November 07, 2014, 10:40:46 pm »
Hi Marmomi,
I see you are based in the UK can you explain why the items supplied come from NL instead of the UK?
mudway
« Reply #185 on: November 08, 2014, 01:40:19 am »
They also come from New York. I suppose that is where the actual machines are.
Marmoi
« Reply #186 on: November 08, 2014, 06:54:35 am »
My shop - 3D Boats - is on the Shapeways site, Shapeways is a 3D printing agency who has 3D printing factories in Holland and America.
deadbeat
« Reply #187 on: November 08, 2014, 12:28:32 pm »
Re 1/24 S100 bridge dimensions.
Taking measurements off my 1/25 plans the measurements were:
Height 50mm
Fore-aft 140mm
Athwartships 164mm
They would be slightly different for a 1/24 scale but only slightly - a mill or two.
Please wait to see if any other confirmation comes in.
Design looks good and would help me a lot, depending on price of course.
Marmoi
« Reply #188 on: November 09, 2014, 06:46:01 am »
Ok, I have had 2 replies and the dimensions seem near enough correct without an original dimensioned drawing., so I have released the model;
Thank you for your help
https://www.shapeways.com/model/2837470/s100-schnellboot-bridge-1-24.html
As the model is so large it will be produced in the sintered Nylon material, which gives it very good strength. To finish this material I would advise the use of a spray filler and rub down with fine wet and dry.
Marmoi
« Reply #189 on: November 12, 2014, 03:47:46 pm »
Klunk
« Reply #190 on: November 12, 2014, 07:40:05 pm »
you must have waaaay too much time to do these!! %%
full time penguin
Marmoi
« Reply #191 on: November 12, 2014, 09:47:11 pm »
I wish, I wouldn't have such a backlog of models to draw up then  {-)
Marmoi
« Reply #192 on: November 15, 2014, 05:43:55 pm »
These two have been in the pipe for a while, but needed a bit of experimentation to get right.
The blocks will need finishing with copper eyelets (see assembly instructions for details), as the printed material at this size proved far to brittle.
There has long be a requirement for scale 1:96 pulley blocks and cargo pulleys, I hope with these they should now be possible.
The pulley blocks come in a set of 48;
https://www.shapeways.com/model/2766711/block-pulley-non-working-x-48-1-96.html
The Cargo pulleys come in a set of 16;
https://www.shapeways.com/model/2766692/?li=aeTabs
gra2
« Reply #193 on: November 25, 2014, 06:35:08 am »
Photo of my Shapeways S100 bridge received today.
If Marmoi happens to look package indicates Matl as WSF SH# 1 #1/1.
Is this the Sintered Nylon Matl that you indicated in the earlier post.
Graham
Marmoi
« Reply #194 on: November 25, 2014, 11:29:01 am »
Hi Graham,
Yes, WSF is "White Strong and Flexible" which is the sintered Nylon.
Mark
gra2
« Reply #195 on: November 25, 2014, 11:47:00 am »
Thanks Mark.
Graham
deadbeat
« Reply #196 on: November 25, 2014, 01:56:47 pm »
My S100 bridge is in transit, looking forward to receiving it. Looks good. it'll save a lot of work that's for sure.
carlmt
    • Linkspan Models
« Reply #197 on: November 25, 2014, 07:07:49 pm »
I am using sintered nylon for the 1:96 fittings on our ferry kits.
In tests, the parts glue together well with a medium thickness superglue and take humbrol paint easily.
With the paint, however, be careful because it will bleed through the material. Once applied, you cannot remove it - it soaks into the component due to the way that the part is built up on the 3D printer....it is porous on the microscopic level!!!
Marmoi
« Reply #198 on: November 25, 2014, 07:27:20 pm »
I always give the parts a gentle rub down and then seal the parts with Halfords filler primer and rub down with 1200 wet & dry and lots of water, this levels the surface and acts as a good base for the final finish.
http://www.halfords.com/motoring/paints-body-repairs/car-spray-paints/halfords-filler-primer-500ml
Marmoi
« Reply #199 on: December 01, 2014, 11:40:22 am »
 %%  Its Cyber Monday and there is 20% off all orders placed today!  %%
Just enter CYBER20 at Checkout
Remember, this is for today (Monday 1st December 2014)  ONLY
Pages: 1 2 3 4 5 6 7 [8] 9 10 11   Go Up
