Author Topic: Sticking clear plasticard to white metal  (Read 3208 times)
chingdevil
« on: June 22, 2007, 04:41:53 pm »
What is the best adhesive to stick clear plasticard to white metal fittings. I am glazing the bridge of my puffer, I have tried super glue but that fogs everything as it dries. Any help much appreciated.
The other Brian
Re: Sticking clear plasticard to white metal
« Reply #1 on: June 22, 2007, 04:52:40 pm »
I use contact adhesive such as EvoStick.
chromedome
« Reply #2 on: June 22, 2007, 05:32:42 pm »
Formula 560.
  chromedome
Bunkerbarge
« Reply #3 on: June 23, 2007, 01:56:26 am »
Funnily enough I have just done the same job on mine, although an Irish sea Steamer still acetate sheet onto painted white metal.
I cut the sheet to sit on the flat of the internal face of the frame because if I tried to fit it into the frame itself the sheet was always flexed slightly and caught the light wrong.  So I held the acetate sheet in the right place inside and I touched the edge of the sheet with a paintbrush loaded with watered down white PVA glue.  The glue dries clear and does not mark the sheet in any way.  When this first application had dried I went over it again to ensure it was sealed around the edges completely.
I am sure if I stick my finger through it it will push out but then I think that would go for a lot of glues anyway and I have a nice flat glaze with no glue marks at all.
You can just make out the glaze in this picture.
