Sorry people, I put the info for the Pump onto the instruction leaflet but left it off the on-line shop's details - what an idiot!!
Hear is the full spec. for this unit.
Connection is via battery connection wires.
Also includes two off silicone tubing.
Input Voltage is 6 - 12volts dc
Current draw is 80mA
Flow Rate is 0-60 ml/min Higher the input voltage - faster the rotation rate - faster the flow rate.
Pump Rotation Speed is 0.1-100rpm
Motor Size is Dia. 27.6 x Height 37.9mm
Pump Size is Dia. 31.7 x Height 20.1mm
The Flow Direction is controlled by the positive and negative connections.
All of this info. is available on the on-line shop at
www.huntersystems.co.uk where you will find all of the info. such as email address and ordering details.
I must warn you about the stock levels and price. The unit has been a raging success and has taken us by surprise. The stock that we built has gone down very fast. The problem I have is that I am about to go into hospital again for another round of operations which will hit my production for at least three weeks afterwards so please be patient.
I set the RRP at £24.95 as being the standard costing but then set the first hundred at the special price of £17.95 given £5 off. Once the first hundred have gone the price will have to go up a wee bit to make a profit - sorry.
Graham
